ESP32 boards
Re: ESP32 boards
It is not possible to set IP Settings in Config tab. Can this somehow be changed.
regards
karl
regards
karl
Re: ESP32 boards
Hi Karl,
Great news!
Out of interest, which ESP32 model is it you are using there?
I agree with you, special thanks to LisaM for all her hard work on this!
Andrew
Great news!
Andrew
Re: ESP32 boards
Hmmm, checking...
@karl: can you verify the correct values are written in the config?
"ssid": and "key": should have the right values!To verify:
- Goto webgui
- tools
- filesystem - files
- click on config
- click on network
- click the edit button
After changing the ssid values, a reboot is necessary.
I'm also busy with finding out why on all platforms async is work, except for the esp32...
Re: ESP32 boards
Ssid and pw do have the right values, but i can’t enter values in ip settings field, they are greyed out...
Re: ESP32 boards
Generally yes, i do most of stuff with fixed ip but i can do it via fixing on router level as well...
Karl
Karl
Re: ESP32 boards
Hi Lisa,
Just chipping in here if I may. In my case I would like to specify a fixed IP-address within the ESP32, please, as my wireless router only allows a limited number of fixed addresses in its table.
Cheers
Andrew
Re: ESP32 boards
V0.2.2 released, firmware can be found in the release section.
Issues solved:
- Async ESP32 not working (work-around implemented: devices should be sending data to domoticz now)
Features added:
- Fixed IP Address possible for ESP32
Issues solved:
Features added:
Re: ESP32 boards
yep, it works
But there still is something funny going on.
When I first create a BME280 device and then a Dallas device, right after the selection of the dallas and clicking submit, the WEB connection with the ESP is broken and a have to reset the ESP board.
After that, I can continue setting up the dallas device.
Re: ESP32 boards
Update:
The Dallas show up correctly in Domoticz.
The BME has two devices in Domoticz, one for temp and one for weather.
Neither one sohwas values, but 'last seen' is correct.
Re: ESP32 boards
BME should be one device:
1244 VirtualSwitches 1452C 1 uPyEasy Test Temp_Hum_Baro Temp + Humidity + Baro THB1 - BTHR918, BTHGN129 0, 25.9326.24707;0;1014.779;0
Re: ESP32 boards
Hi Lisa,
Thanks for all your hard work on this!
I just tried the latest (20180326) binaries for ESP32 on my Lolin32 Lite board. Getting closer but still some issues.
2048.bin:
Working with only the BME280 and DomoticzMQTT, can see Async processes running, values being updated - all good.
BUT, when I tried to add DS18B20, after clicking Submit to select DS18B20 the bottom two thirds of the screen was the one for BME280 (I2C address, three value settings (Temp, Press, Hum)!
I tried 'Submit' at the bottom anyway...
The main Devices page showed the "real" BME280, plus a device with three values (Temperature, Pressue, Humidity)! (It's a mutant!! )
4096.bin:
Similar to above. OK with Domoticz and BME280, Async process running, values being updated, all good.
This time when I tried to add DS18B20, it crashed as soon as I clicked 'Submit' to select it. See log below.
2018-03-27 15:06:20 [debug] uPyEasy-uPyEasy: Pages: Entering Device Settings Page
2018-03-27 15:06:20 [debug] uPyEasy-uPyEasy: Pages: POST
2018-03-27 15:06:20 [debug] uPyEasy-uPyEasy: id
2018-03-27 15:06:20 [debug] uPyEasy-uPyEasy: 0
2018-03-27 15:06:20 [debug] uPyEasy-uPyEasy: New Plugin: 4
2018-03-27 15:06:20 [debug] uPyEasy-uPyEasy: Pages: Create Device
2018-03-27 15:06:20 [debug] uPyEasy-uPyEasy: Pages: New Device and plugin choosen: 4
2018-03-27 15:06:21 [debug] uPyEasy-uPyEasy: Utils: uPyEasy Name
2018-03-27 15:06:22 [debug] uPyEasy-uPyEasy: Plugins: Init device: dummy with plugin: 4
2018-03-27 15:06:22 [debug] uPyEasy-uPyEasy: Protocols: GetQueue controller 192.168.1.12-Domoticz MQTT-1
2018-03-27 15:06:22 [debug] uPyEasy-uPyEasy: Plugin: ds18 contruction
2018-03-27 15:06:23 [debug] uPyEasy-uPyEasy: Plugin: ds18 contruction
2018-03-27 15:06:23 [debug] uPyEasy-uPyEasy: Plugins: Init device: dummy ,instantiate plugin: DS18B20
2018-03-27 15:06:23 [debug] uPyEasy-uPyEasy: Utils: uPyEasy Name
2018-03-27 15:06:23 [debug] uPyEasy-uPyEasy: Plugin: ds18 init
2018-03-27 15:06:23 [debug] uPyEasy-uPyEasy: Plugins: Read device store: dummy
2018-03-27 15:06:23 [debug] uPyEasy-uPyEasy: Plugin: ds18 init, pin used:
2018-03-27 15:06:23 [debug] uPyEasy-uPyEasy: Hal: pin =
File "boot.py", line 3, in <module>
File "upyeasy/__init__.py", line 65, in main
File "picoweb/__init__.py", line 298, in run
File "uasyncio/core.py", line 146, in run_forever
File "uasyncio/core.py", line 101, in run_forever
File "picoweb/__init__.py", line 210, in _handle
AttributeError: 'Log' object has no attribute 'exc'
OSError: [Errno 2] ENOENT
MicroPython v1.9.3-479-gb63cc1e-dirty on 2018-03-26; ESP32 module with ESP32
Type "help()" for more information.
So it looks like Async processes are fixed now, but an issue with DS18B20.
I really appreciate all the work you are doing on this. If there's any more information you'd like, let me know. Can I help in any way with debugging?
Cheers
Andrew
Re: ESP32 boards
With the latest firmware, the Dallas sensor is working towards Domoticz and has been running for several hours.
One strange thing however:
This module has previously been used to check Dallas on ESPEasy32 and it has two dallas sensors attached (same pin).
uPyEasy has only 1 device configured but it seems to read both sensors anyway and it sends them both to Domoticz using the same IDX.
Re: ESP32 boards
The ds18b20 plugin was a rush job to get it working, it was never intended to read two dallas sensors. I'm amazed it can actually do that...Martinus wrote: ↑27 Mar 2018, 16:59 With the latest firmware, the Dallas sensor is working towards Domoticz and has been running for several hours.
It definitely needs some improvements...
Re: ESP32 boards
I created a dummy device in Domotic, type: TEMP+HUM+BARO
upyeasy1 Ja Dummy (Does nothing, use for virtual switches only) Maak virtuele sensoren
And it appears like this in the devices list:
361 upyeasy1 141B9 1 UPYEASy Temp + Humidity + Baro THB1 - BTHR918, BTHGN129 0, 18.045.31738;0;1005.792;0
- UPYEASY2.PNG (9.07 KiB) Viewed 41617 times
- UPYEASY1.PNG (7.32 KiB) Viewed 41619 times
Re: ESP32 boards
Looks like a Domoticz bug... The values are there...
Re: ESP32 boards
Update:
I forgot to mention before, the Fixed IP Address is working for me. Thanks!
Andrew
Re: ESP32 boards
Probably not.
This is with the BME on a ESPEasy:
364 ESP16 141BC 1 BME1 Temp + Humidity + Baro THB1 - BTHR918, BTHGN129 22.0 C, 37 %, 1005 hPa
It looks like the string has a different format then.
- ESPEASY2.PNG (11.02 KiB) Viewed 41602 times
- ESPEASY1.PNG (12.05 KiB) Viewed 41602 times
Re: ESP32 boards
Owwwww, then it must be a uPyEasy domoticz http controller bug! I'll check this out...
Re: ESP32 boards
With the latest release, after installation and restart, I get:
After that, no communication possible.
rst:0x10 (RTCWDT_RTC_RESET),boot:0x3e (SPI_FAST_FLASH_BOOT)
configsip: 0, SPIWP:0xee
mode:DIO, clock div:2
load:0x3fff0018,len:4
load:0x3fff001c,len:4464
ho 0 tail 12 room 4
load:0x40078000,len:0
load:0x40078000,len:11816
entry 0x4007a9fc
I (467) cpu_start: Pro cpu up.
I (467) cpu_start: Single core mode
I (468) heap_init: Initializing. RAM available for dynamic allocation:
I (471) heap_init: At 3FFAE6E0 len 00001920 (6 KiB): DRAM
I (477) heap_init: At 3FFC4E98 len 0001B168 (108 KiB): DRAM
I (483) heap_init: At 3FFE0440 len 00003BC0 (14 KiB): D/IRAM
I (490) heap_init: At 3FFE4350 len 0001BCB0 (111 KiB): D/IRAM
I (496) heap_init: At 4008DE34 len 000121CC (72 KiB): IRAM
I (502) cpu_start: Pro cpu start user code
I (73) cpu_start: Starting scheduler on PRO CPU.
I (140) modsocket: Initializing
File "ulog.py", line 110, in do_log
File "syslog_sink.py", line 78, in log
File "usyslog.py", line 60, in error
File "usyslog.py", line 82, in log
OSError: 118
2000-01-01 00:00:02 [error] uPyEasy: Hal: esp32, ssid empty
File "syslog_sink.py", line 76, in log
File "usyslog.py", line 72, in warning
OSError: 118
2000-01-01 00:00:02 [warning] uPyEasy: Hal: init esp32 network: AP mode
I (2890) wifi: wifi firmware version: ebd3e5d
I (2890) wifi: config NVS flash: enabled
I (2890) wifi: config nano formating: disabled
I (2900) system_api: Base MAC address is not set, read default base MAC address from BLK0 of EFUSE
I (2910) system_api: Base MAC address is not set, read default base MAC address from BLK0 of EFUSE
I (2920) wifi: Init dynamic tx buffer num: 32
I (2920) wifi: Init data frame dynamic rx buffer num: 64
I (2930) wifi: Init management frame dynamic rx buffer num: 64
I (2930) wifi: wifi driver task: 3ffd0f0c, prio:23, stack:4096
I (2940) wifi: Init static rx buffer num: 10
I (2940) wifi: Init dynamic rx buffer num: 0
I (2940) wifi: wifi power manager task: 0x3ffd5b5c prio: 21 stack: 2560
I (3000) phy: phy_version: 383.0, 79a622c, Jan 30 2018, 15:38:06, 0, 0
I (3000) wifi: mode : null
I (3010) wifi: mode : softAP (30:ae:a4:22:e8:1d)
I (3010) network: event 13
I (3120) network: event 14
I (3120) network: event 13
2000-01-01 00:00:04 [info] uPyEasy-uPyEasy: Main: uPyEasy running in Access Point mode
2000-01-01 00:00:04 [info] uPyEasy-uPyEasy: Main: uPyEasy Main Async Loop on IP adress: 0.0.0.0:80
Re: ESP32 boards
The above happens with two versions of the ESP32 board, with both the 4096 and the 2048 version.
With a third board, I got:
D:\Program Files\Python\Python36>python esptool-master\esptool.py --port COM5 write_flash --compress 0x1000 D:\Tools\uPython\upyeasy-esp32\upyeasy_v030_20180506_test_esp32_2048.bin
esptool.py v2.3-dev
Connecting....
Detecting chip type... ESP32
Chip is ESP32D0WDQ6 (revision 1)
Uploading stub...
Running stub...
Stub running...
Configuring flash size...
Auto-detected Flash size: 4MB
Flash params set to 0x0220
Compressed 1278000 bytes to 728894...
Writing at 0x0007d000... (71 %)
A fatal error occurred: Failed to write compressed data to flash after seq 31 (result was C100)
esptool.py v2.3-dev
Connecting....
Uploading stub...
Running stub...
Stub running...
Re: ESP32 boards
After a second attempt with one of the boards, with the 2048 version, I got:
rst:0x1 (POWERON_RESET),boot:0x17 (SPI_FAST_FLASH_BOOT)
ho 0 tail 12 room 4
entry 0x4007a9fc
I (465) cpu_start: Pro cpu up.
I (465) cpu_start: Single core mode
I (466) heap_init: Initializing. RAM available for dynamic allocation:
I (469) heap_init: At 3FFAE6E0 len 00001920 (6 KiB): DRAM
I (475) heap_init: At 3FFC4E98 len 0001B168 (108 KiB): DRAM
I (481) heap_init: At 3FFE0440 len 00003BC0 (14 KiB): D/IRAM
I (488) heap_init: At 3FFE4350 len 0001BCB0 (111 KiB): D/IRAM
I (494) heap_init: At 4008DE34 len 000121CC (72 KiB): IRAM
I (500) cpu_start: Pro cpu start user code
I (71) cpu_start: Starting scheduler on PRO CPU.
File "upyeasy/__init__.py", line 46, in main
File "upyeasy/init.py", line 206, in init
File "upyeasy/db.py", line 593, in getrow
File "upyeasy/db.py", line 591, in getrow
File "filedb.py", line 111, in get
ValueError: syntax error in JSON
MicroPython v1.9.3-549-gbe9277b-dirty on 2018-05-06; ESP32 module with ESP32
>>> upyeasy.setwifi('xxxxxx','yyyyyyyyy')
cache deleted: _config
>>> import machine
>>> machine.reset()
Guru Meditation Error: Core 0 panic'ed (IllegalInstruction)
. Exception was unhandled.
Guru Meditation Error: Core 0 panic'ed (|▒?22@P▒?s▒?▒▒?▒▒?22@3)
? Exception w22@3Guru Meditation Error: Core 0 panic'ed (|▒?22@P▒?s▒?▒▒?▒▒?22@3 )
? Exception w22@3Guru Meditation Error: Core 0 panic'ed #|▒?22@P▒?s▒?▒▒?▒▒?22@3 ? Exception w22@3Guru Meditation Error: Core 0 panic'ed #|▒?22@P▒?s▒?▒▒?▒▒?22@3 ? Exception w22@3Guru Meditation Error: Core 0 panic'ed #|▒?22@P▒?s▒?▒▒?▒▒?22@3 ? Exception w22@3Guru Meditation Error: Core 0 panic'ed #|▒?22@P▒?s▒?▒▒?▒▒?22@3 ? Exception w22@3Guru Meditation Error: Core 0 panic'ed #|▒?22@P▒?s▒?▒▒?▒▒?22@3 ? Exception w22@3Guru Meditation Error: Core 0 panic'ed #|▒?22@P▒?s▒?▒▒?▒▒?22@3 ? Exception w22@3Guru Meditation Error: Core 0 panic'ed #|▒?22@P▒?s▒?▒▒?▒▒?22@3 ? Exception w22@3Guru Meditation Error: Core 0 panic'ed #|▒?22@P▒?s▒?▒▒?▒▒?22@3 ? Exception w22@3Guru Meditation Error: Core 0 panic'ed #|▒?22@P▒?s▒?▒▒?▒▒?22@3 ? Exception w22@3Guru Meditation Error: Core 0 panic'ed #|▒?22@P▒?s▒?▒▒?▒▒?22@3 ? Exception w22@3Guru Meditation Error: Core 0 panic'ed #|▒?22@P▒?s▒?▒▒?▒▒?22@3 ? Exception w22@3Guru Meditation Error: Core 0 panic'ed #|▒?22@P▒?s▒?▒▒?▒▒?22@3 ? Exception w22@3Guru Meditation Error: Core 0 panic'ed #Guru Meditation Error: Core 0 panic'ed #Guru Meditation Error: Core 0 panic'ed #Guru Meditation Erro r: Core 0 panic'ed #Guru Meditation Error: Core 0 panic'ed #Guru Meditation Er ror: Core 0 panic'ed #Guru Meditation Error: Core 0 panic'ed #Guru Meditation Error: Core 0 panic'ed #Guru Meditation Error: Core 0 panic'ed #Guru Meditatio n Error: Core 0 panic'ed #Guru Meditation Error: Core 0 panic'ed #Guru Meditat ion Error: Core 0 panic'ed #Guru Meditation Error: Core 0 panic'ed #Guru Medit ation Error: Core 0 panic'ed #Guru Meditation Error: Core 0 panic'ed #Guru Med itation Error: Core 0 panic'ed #Guru Meditation Error: Core 0 panic'ed #Guru M editation Error: Core 0 panic'ed #Guru Meditation Error: Core 0 panic'ed #Guru Meditation Error: Core 0 panic'ed #Guru Meditation Error: Core 0 panic'ed #Gu ru Meditation Error: Core 0 panic'ed #Guru Meditation Error: Core 0 panic'ed # Guru Meditation Error: Core 0 panic'ed #Guru Meditation Error: Core 0 panic'ed #Guru Meditation Error: Core 0 panic'ed #Guru Meditation Error: Core 0 panic' ed #Guru Meditation Error: Core 0 panic'ed #Guru Meditation Error: Core 0 pani c'ed #▒▒?22@3Guru Meditation Error: Core 0 panic'ed #Guru Meditation Error: Cor e 0 panic'ed #Guru Meditation Error: Core 0 panic'ed #Guru Meditation Error: C ore 0 panic'ed #Guru Meditation Error: Core 0 panic'ed #Guru Meditation Error: Core 0 panic'ed #Guru Meditation Error: Core 0 panic'ed #Guru Meditation Erro r: Core 0 panic'ed #Guru Meditation Error: Core 0 panic'ed #Guru Meditation Er ror: Core 0 panic'ed #Guru Meditation Error: Core 0 panic'ed #Guru Meditation Error: Core 0 panic'ed #Guru Meditation Error: Core 0 panic'ed #Guru Meditatio n Error: Core 0 panic'ed #Guru Meditation Error: Core 0 panic'ed #Guru Meditat ion Error: Core 0 panic'ed #Guru Meditation Error: Core 0 panic'ed #Guru Medit ation Error: Core 0 panic'ed #Guru Meditation Error: Core 0 panic'ed #Guru Med itation Error: Core 0 panic'ed #Guru Meditation Error: Core 0 panic'ed #Guru M editation Error: Core 0 panic'ed #Guru Meditation Error: Core 0 panic'ed #Guru Meditation Error: Core 0 panic'ed #▒▒?22@3Guru Meditation Error: Core 0 panic 'ed #▒▒?22@3Guru Meditation Error: Core 0 panic'ed #Guru Meditation Error: Core 0 panic'ed #Guru Meditation Error: Core 0 panic'ed #Unknown reasonGuru Medita tion Error: Core 0 panic'ed #Unknown reasonGuru Meditation Error: Core 0 panic 'ed #Unknown reasonGuru Meditation Error: Core 0 panic'ed #▒@pT▒?? Exception w2 2@3ets Jun 8 2016 00:22:57
rst:0x10 (RTCWDT_RTC_RESET),boot:0x17 (SPI_FAST_FLASH_BOOT)
ho 0 tail 12 room 4
entry 0x4007a9fc
I (466) cpu_start: Pro cpu up.
I (466) cpu_start: Single core mode
I (470) heap_init: At 3FFAE6E0 len 00001920 (6 KiB): DRAM
I (476) heap_init: At 3FFC4E98 len 0001B168 (108 KiB): DRAM
I (482) heap_init: At 3FFE0440 len 00003BC0 (14 KiB): D/IRAM
I (495) heap_init: At 4008DE34 len 000121CC (72 KiB): IRAM
I (501) cpu_start: Pro cpu start user code
Re: ESP32 boards
Hi Bert,
There have been database changes, can you erase the esp32, reflash and then try again? If you have settings in the database you want to remember, save/write/note it down first.
Cheers,
Lisa
Cheers,
Lisa
Re: ESP32 boards
Hi Lisa,
I did this esptool.py --port COM5 erase_flash as my first action on all boards.
Re: ESP32 boards
Hi Bert,
This might be due to a to long build version in the config table, if have shortened it and put a new firmware version in the release section.
Can you erase/flash the esp32 again?
Cheers,
Lisa
Cheers,
Lisa
Re: ESP32 boards
Hi Lisa,
This happends after loading the 4096 version. It stops right after the 80.
rst:0x1 (POWERON_RESET),boot:0x13 (SPI_FAST_FLASH_BOOT)
flash read err, 1000
Falling back to built-in command interpreter.
OK
rst:0x10 (RTCWDT_RTC_RESET),boot:0x13 (SPI_FAST_FLASH_BOOT)
ho 0 tail 12 room 4
entry 0x4007a9fc
I (467) heap_init: Initializing. RAM available for dynamic allocation:
I (489) heap_init: At 3FFE4350 len 0001BCB0 (111 KiB): D/IRAM
I (72) cpu_start: Starting scheduler on PRO CPU.
OSError: 118
OSError: 118
I (2990) wifi: wifi firmware version: ebd3e5d
I (2990) wifi: config NVS flash: enabled
I (2990) wifi: config nano formating: disabled
I (2990) system_api: Base MAC address is not set, read default base MAC address from BLK0 of EFU SE
I (3000) system_api: Base MAC address is not set, read default base MAC address from BLK0 of EFU SE
I (3020) wifi: Init dynamic tx buffer num: 32
I (3020) wifi: Init data frame dynamic rx buffer num: 64
I (3020) wifi: Init management frame dynamic rx buffer num: 64
I (3030) wifi: wifi driver task: 3ffd0f0c, prio:23, stack:4096
I (3030) wifi: Init static rx buffer num: 10
I (3040) wifi: Init dynamic rx buffer num: 0
I (3040) wifi: wifi power manager task: 0x3ffd5b5c prio: 21 stack: 2560
I (3100) phy: phy_version: 383.0, 79a622c, Jan 30 2018, 15:38:06, 0, 0
I (3110) wifi: mode : null
I (3110) wifi: mode : softAP (30:ae:a4:0d:6a:bd)
I (3110) network: event 13
I (3220) network: event 14
I (3230) network: event 13
2000-01-01 00:00:05 [info] uPyEasy-uPyEasy: Main: uPyEasy running in Access Point mode
2000-01-01 00:00:05 [info] uPyEasy-uPyEasy: Main: uPyEasy Main Async Loop on IP adress: 0.0.0.0: 80
80
Re: ESP32 boards
Okay.
When I after the 80 enter ctrl C, I get:
Afther that, I could enter the setwifi, the import machine and the machine.reset()
Thereafter I got:
Now, something seems to be alive ...
File "upyeasy/__init__.py", line 85, in main
File "upyeasy/__init__.py", line 83, in main
File "picoweb/__init__.py", line 311, in run
File "uasyncio/core.py", line 77, in run_forever
File "uasyncio/__init__.py", line 69, in wait
KeyboardInterrupt:
MicroPython v1.9.3-549-gbe9277b-dirty on 2018-05-16; ESP32 module with ESP32
Thereafter I got:
>>> upyeasy.setwifi('wifiSSID','wifi password')
>>> import machine
>>> machine.reset()
I (139119) network: event 3
I (139119) wifi: flush txq
I (139119) wifi: stop sw txq
I (139119) wifi: lmac stop hw txq
? Exception w22@3Guru Meditation Error: Core 0 panic'ed #|▒?22@P▒?s▒?▒▒?▒▒?22@3 ? Exception w22@3Guru Meditation Error: Core 0 panic'ed #|▒?22@P▒?s▒?▒▒?▒▒?22@3 ? Exception w22@3Guru Meditation Error: Core 0 panic'ed #|▒?22@P▒?s▒?▒▒?▒▒?22@3 ? Exception w22@3Guru Meditation Error: Core 0 panic'ed #|▒?22@P▒?s▒?▒▒?▒▒?22@3 ? Exception w22@3Guru Meditation Error: Core 0 panic'ed #|▒?22@P▒?s▒?▒▒?▒▒?22@3 ? Exception w22@3Guru Meditation Error: Core 0 panic'ed #|▒?22@P▒?s▒?▒▒?▒▒?22@3 ? Exception w22@3Guru Meditation Error: Core 0 panic'ed #|▒?22@P▒?s▒?▒▒?▒▒?22@3 ? Exception w22@3Guru Meditation Error: Core 0 panic'ed #|▒?22@P▒?s▒?▒▒?▒▒?22@3 ? Exception w22@3Guru Meditation Error: Core 0 panic'ed #|▒?22@P▒?s▒?▒▒?▒▒?22@3 ? Exception w22@3Guru Meditation Error: Core 0 panic'ed #|▒?22@P▒?s▒?▒▒?▒▒?22@3 ? Exception w22@3Guru Meditation Error: Core 0 panic'ed #|▒?22@P▒?s▒?▒▒?▒▒?22@3 ? Exception w22@3Guru Meditation Error: Core 0 panic'ed #|▒?22@P▒?s▒?▒▒?▒▒?22@3 ? Exception w22@3Guru Meditation Error: Core 0 panic'ed #Guru Meditation Error: Core 0 panic'ed #Guru Meditation Error: Core 0 panic'ed #Guru Meditation Erro r: Core 0 panic'ed #Guru Meditation Error: Core 0 panic'ed #Guru Meditation Er ror: Core 0 panic'ed #Guru Meditation Error: Core 0 panic'ed #Guru Meditation Error: Core 0 panic'ed #Guru Meditation Error: Core 0 panic'ed #Guru Meditatio n Error: Core 0 panic'ed #Guru Meditation Error: Core 0 panic'ed #Guru Meditat ion Error: Core 0 panic'ed #Guru Meditation Error: Core 0 panic'ed #Guru Medit ation Error: Core 0 panic'ed #Guru Meditation Error: Core 0 panic'ed #Guru Med itation Error: Core 0 panic'ed #Guru Meditation Error: Core 0 panic'ed #Guru M editation Error: Core 0 panic'ed #Guru Meditation Error: Core 0 panic'ed #Guru Meditation Error: Core 0 panic'ed #Guru Meditation Error: Core 0 panic'ed #Gu ru Meditation Error: Core 0 panic'ed #Guru Meditation Error: Core 0 panic'ed # Guru Meditation Error: Core 0 panic'ed #Guru Meditation Error: Core 0 panic'ed #Guru Meditation Error: Core 0 panic'ed #Guru Meditation Error: Core 0 panic' ed #Guru Meditation Error: Core 0 panic'ed #Guru Meditation Error: Core 0 pani c'ed #▒▒?22@3Guru Meditation Error: Core 0 panic'ed #Guru Meditation Error: Cor e 0 panic'ed #Guru Meditation Error: Core 0 panic'ed #Guru Meditation Error: C ore 0 panic'ed #Guru Meditation Error: Core 0 panic'ed #Guru Meditation Error: Core 0 panic'ed #Guru Meditation Error: Core 0 panic'ed #Guru Meditation Erro r: Core 0 panic'ed #Guru Meditation Error: Core 0 panic'ed #Guru Meditation Er ror: Core 0 panic'ed #Guru Meditation Error: Core 0 panic'ed #Guru Meditation Error: Core 0 panic'ed #Guru Meditation Error: Core 0 panic'ed #Guru Meditatio n Error: Core 0 panic'ed #Guru Meditation Error: Core 0 panic'ed #Guru Meditat ion Error: Core 0 panic'ed #Guru Meditation Error: Core 0 panic'ed #Guru Medit ation Error: Core 0 panic'ed #Guru Meditation Error: Core 0 panic'ed #Guru Med itation Error: Core 0 panic'ed #Guru Meditation Error: Core 0 panic'ed #Guru M editation Error: Core 0 panic'ed #Guru Meditation Error: Core 0 panic'ed #Guru Meditation Error: Core 0 panic'ed #▒▒?22@3Guru Meditation Error: Core 0 panic 'ed #▒▒?22@3Guru Meditation Error: Core 0 panic'ed #Guru Meditation Error: Core 0 panic'ed #ets Jun 8 2016 00:22:57
ho 0 tail 12 room 4
entry 0x4007a9fc
I (139) modsocket: Initializing
I (2829) wifi: wifi firmware version: ebd3e5d
I (2829) wifi: config NVS flash: enabled
I (2829) wifi: config nano formating: disabled
I (2829) system_api: Base MAC address is not set, read default base MAC address from BLK0 of EFUSE
I (2839) system_api: Base MAC address is not set, read default base MAC address from BLK0 of EFUSE
I (2849) wifi: Init dynamic tx buffer num: 32
I (2849) wifi: Init data frame dynamic rx buffer num: 64
I (2859) wifi: Init management frame dynamic rx buffer num: 64
I (2859) wifi: wifi driver task: 3ffd0f0c, prio:23, stack:4096
I (2869) wifi: Init static rx buffer num: 10
I (2869) wifi: Init dynamic rx buffer num: 0
I (2879) wifi: wifi power manager task: 0x3ffd5b5c prio: 21 stack: 2560
I (2939) phy: phy_version: 383.0, 79a622c, Jan 30 2018, 15:38:06, 0, 0
I (2939) wifi: mode : null
I (2939) wifi: mode : sta (30:ae:a4:0d:6a:bc)
I (2949) wifi: STA_START
I (3799) wifi: n:7 1, o:1 0, ap:255 255, sta:7 1, prof:1
I (4349) wifi: state: init -> auth (b0)
I (4419) wifi: state: auth -> assoc (0)
I (4429) wifi: state: assoc -> run (10)
I (4439) wifi: connected with yyyyyy, channel 7
I (4449) network: event 4
I (5149) event: sta ip: xxxx, mask: xxxxxxx, gw: xxxxxxxxx
I (5149) network: GOT_IP
I (7429) wifi: pm start, type:0
2018-05-17 19:20:47 [info] uPyEasy-uPyEasy: Main: uPyEasy running in Station mod e
2018-05-17 19:20:47 [info] uPyEasy-uPyEasy: Main: uPyEasy Main Async Loop on IP adress: xxxxxxxxx:80
