Input switch ... only ON needed
Moderators: BertB, Voyager, grovkillen, Stuntteam, LisaM
martmiwp
#1 Post by martmiwp » 15 Nov 2018, 20:11
Hi!
First I want to tell you how much I am impressed on what you are doing!!! Great Job!
It is related to the Volkszaehler.org and the transmission of pulses from the meter.
When a pulse is given, I need to post a "1" via http to the server.
Everyhing I could manage very easily - thanks to the selfxplanatory UI.
My need:
I only want to send a "1" .... NOT the "0"
I used a switch input - but how to manage that only the positive pulse is sent.... any thoughts?
I tried a pulse measurement device - but this sends on a timed fashion ... not event driven.
Any help would be appreaciated !
Michael
It is related to the ESP Easy Mega - mega-20181112 ... Maybe I picked the wrong board??
toffel969
Re: Input switch ... only ON needed
#2 Post by toffel969 » 19 Nov 2018, 14:09
martmiwp wrote:
15 Nov 2018, 20:11
Hi!
My need:
Michael
Hi assuming a switch input device named Pulse you could try the following. Disable the controller for the switch.
Enable rules under advanced . The rules tab will appear.
Then try to set up a rule:
On Pulse#switch=1 do
SendToHTTP "desiredURL"
This should do the trick
