A new plugin is added in the end of the year. With Dash plugin the locally added Tasks can be visualised in a table.
Plugin interval defines the page refresh rate, page can be accessed by IP/dash or can be setted to force itself as startpage.
P212 Dashboard plugin
Moderators: grovkillen, Stuntteam, TD-er, enesbcs
- rpieasy_devlist.jpg (207.56 KiB) Viewed 510 times
- rpieasy_dash.jpg (110.43 KiB) Viewed 510 times
Re: P212 Dashboard plugin
Hmm that run button is also a good idea to have in ESPeasy.
Yep, it simply executes taskrun command.
And the next button Toggle is for binary outputs only, changes state between 0 and 1.
- budman1758
Thats a great idea! I just updated on of my units but can't seem to be able to access it. How do you enable this?
EDIT: Nevermind... Found it.
Add some tasks that generates data, than add a P212 Dash plugin and setup:budman1758 wrote: ↑05 Jan 2021, 16:54 Thats a great idea! I just updated on of my units but can't seem to be able to access it. How do you enable this?
- Size (table)
- Data type [ Text, Binary input/read only, Switch output/changeable, Meter, Gauge, Slider output (dimmer), Select output (has to fill displayed and send values) ]
- Data source (select task+value name)
If the type supports, you can also add "unit" or min/max values.
The result can be accessed at http://ip_addres/dash
- rpieas_dash_setup.jpg (90.21 KiB) Viewed 457 times
