P212 Dashboard plugin
Moderators: grovkillen, Stuntteam, TD-er, enesbcs
enesbcs
#1 Post by enesbcs » 31 Dec 2020, 12:26
A new plugin is added in the end of the year. With Dash plugin the locally added Tasks can be visualised in a table.
Plugin interval defines the page refresh rate, page can be accessed by IP/dash or can be setted to force itself as startpage.
Re: P212 Dashboard plugin
#2 Post by TD-er » 31 Dec 2020, 17:18
Hmm that run button is also a good idea to have in ESPeasy.
enesbcs
#3 Post by enesbcs » 31 Dec 2020, 18:32
TD-er wrote: 31 Dec 2020, 17:18 Hmm that run button is also a good idea to have in ESPeasy.
Yep, it simply executes taskrun command. :)
And the next button Toggle is for binary outputs only, changes state between 0 and 1.
budman1758
#4 Post by budman1758 » 05 Jan 2021, 16:54
Thats a great idea! I just updated on of my units but can't seem to be able to access it. How do you enable this?
EDIT: Nevermind... Found it.
enesbcs
#5 Post by enesbcs » 05 Jan 2021, 17:15
budman1758 wrote: 05 Jan 2021, 16:54 Thats a great idea! I just updated on of my units but can't seem to be able to access it. How do you enable this?
Add some tasks that generates data, than add a P212 Dash plugin and setup:
- Size (table)
- Data type [ Text, Binary input/read only, Switch output/changeable, Meter, Gauge, Slider output (dimmer), Select output (has to fill displayed and send values) ]
- Data source (select task+value name)
If the type supports, you can also add "unit" or min/max values.
The result can be accessed at http://ip_addres/dash
ndull
#6 Post by ndull » 24 Jan 2021, 19:39
Hej,
I don´t find the P212 Dash plugin in the Release mega-20201227 and Release mega-20210114.
I always take the compiled *.bin for flashing.
Thanks greetings from Sverige
ndull
#7 Post by Ath » 24 Jan 2021, 19:55
ndull wrote: 24 Jan 2021, 19:39 Hej,
ndull
P212 is a plugin for RPiEasy, not for ESPEasy...
/Ton
ndull
#8 Post by ndull » 24 Jan 2021, 20:35
Hej Ath,
Sorry. Thanks, who can read has a clear advantage.
enesbcs
#9 Post by enesbcs » 14 Feb 2021, 15:59
Ath wrote: 24 Jan 2021, 19:55
ndull
Yes! Although i've backported Dashboard plugin to mPyEasy for ESP32:
https://github.com/enesbcs/mpyeasy/releases
