Analog mqtt message does not have unit number
Hi All
I hope that you can point me in the right direction.
I have the internal Analog enabled under "Devices" and i am trying to send it to a mqtt broker.
The issue is that it seems that the Analog message does not include the "unit number" so i am just getting the value under the "Unit name" as all my unis have the same name, but each one has an unique unit number.
How do i send the Analog value to the broker that include the Unit name and the unit number so that i can read the correct value per unit?
Or am i going about this wrong?
Z69
Z69
Re: Analog mqtt message does not have unit number
Not sure how you try to send it to the broker.
If no controller fits your needs, you can also create a message in rules and "publish" the data.
For example you can use the analog input plugin to create a task and refer to that value from within the rules.
If you use a VCC build, you can also use the %vcc% to create a MQTT message.
Hi TD-er
Here is my setup
ESPEasy mqtt setup as Home Assistant (openHAB) MQTT
Under "Devices" Analog input - internal, with "Send to Controller" enabled
In mqtt - i use MQTT Explorer to see the info, the Analog value is posted under the Device name and not under the Unit number.
mqtt broker ------->192.xxx.yyy.xxx
Device Name -------->ESP
Device Number-------->1
Topic--------------------->cmd = pwm,12,1023
Analog Name---------->Power
Topic---------------------> Analog = 8.00
As you can see, Power should be one level lower, under the "Device Number" level and not under the "Device Name" level.
If i have four ESP's, all four of them are under the Device name level and i am unable to differentiate between them.
Any assitance will be appreciated
Z69
Here is my setup
Z69
A few more questions:
- What version (.bin filename is the most informative) of ESPEasy do you have installed on your ESP's?
- What type of ESP's do you have, ESP8266 or ESP32?
Hi Ath
ESP_Easy_mega_20200703_normal_ESP8266_4M1M
Please close the Topic, i have resolved the issue by making some changes to the mqtt subscribe topic
We would appreciate if you could share the details, please.
Hi Ath
In my setup, all the ESP's have the same Sysname and each one has it's own number as in 1,2,3...
I have NOT set "Append Unit Number to hostname:"
Here is my mqtt setup, i am still new to mqtt, but this work for me, if there is a better way i am open to any way to do it better.
I had to add the %unit% to the "Controller Publish" to get it to work this way.
Controller Subscribe: %sysname%/%unit%/#
Controller Publish: %sysname%/%unit%/%tskname%/%valname%
Controller LWT Topic: %sysname%/%unit%/
This way, i have one Sysname, the units with their unit numbers are one level lower and each unit messages are under each one's number.
mqtt broker ----->192.xxx.yyy.xxx
Device Name ------>ESP
Device Number------>1
Topic------------------->cmd = pwm,12,1023
Device Number------>2
Z69
Z69
Users browsing this forum: No registered users and 31 guests
