How to erase the NodeMCU from settings
If I want to erase the NodeMCU totally - how can I do that. It seems like the settings is still there after a new upload
Re: How to erase the NodeMCU from settings
Usually erasing the part in ESP memory where the settings are stored is enough.
To do that connect a short between the RX and the TX pin, repower or reset the ESP. Wait a while (minute or so) to let the erase process finish.
Disconnect and reconnect power and your old settings should be cleared.
Thanks I will test that
I did as you said but the nodemcu seems dead
if I connect it to the pc it does not see it and I can not flash
That is really weird. I have used this method several times when something gets stuck. Never had any problem.
Users browsing this forum: No registered users and 86 guests
