I have several devices (R78 and R103) connected to openhab/mqtt via wifi.
Some of them stops responding after working for days/weeks, reason totally unknown.
What happens if the wifi router is rebooted ?
In the code I only see a retry on a MQTT connection when it fails to connect but what if the wifi link is/was down ?
Will it try to establish a wifi connection again ?
Is there a way to do an automatically reboot every xx hours?
-ben
espeasy stops responding
Re: espeasy stops responding
Good question, I also need this info, +1
Ben,
Not sure if you have seen Scargill's home automation controller, but he sends out a heartbeat from a RasPi every minute to esp's, if esp stops getting this, it will first reboot mqtt, there after reboot and reconnect wifi. He has published this as a node-red node as well to control, neat solution to same problem.
http://tech.scargill.net/home-control-2016/
"Whatever controls these boards must now send topic toesp command {heartbeat} every minute. All the boards will see this - and all will pre-set a counter in themselves - which if allowed to drop to zero will re-initialise the MQTT code. In the event that boards lose the WIFI for some time, they may reset their WIFI - then reset the MQTT code. Reset is used only as a last resort and the software can handle up to two SSIDs in case you happen to have two access points. If one fails it will try the other."
Very nicely done, looks impressive.
I did 'standardize' on espeasy due to the wide range of supported interfaces.
I really like the idea of having a heartbeat function over MQTT controlled by (example) OPENHAB.
This should not be difficult to implement and I hope this will be done in the future.
For me a selectable heartbeat would be fine, something between 1 en 10 minutes would be great.
-ben
-ben
Users browsing this forum: No registered users and 29 guests
