Hello Guys,
Thank you for all the time you are spending on this great software, from time to time there are a lot of amazing upgrades (officially and unofficially) work.
I have problem in get the right code of my remote control, i used arduino/espeasy and some other program to read the code from remote control but i didn't understand the code well, or i may not able to classified it under the right position. most of what a got when pressing power-on is "64800024" and most of what i got when pressing power-off is "64800004". also there are other codes for on like: (B7CE9DF1, EEC8B73, 20584F61, 4F8D7F48, 89212F42, 5975E905, 143E7DCE and EC1C9E99)
I tried to send this code again by the IRTX plugin for espeasy and it not reflect anything on my AC unit. while actually there is output from IR transmitter (detected by my camera), also im sending the code by HTTP (http://192.168.2.165/control?cmd=IRSEND ... 0e09966,32), i replaced the SAMSUNG with all other protocols which set in plugin (NEC, JVC, RC5, RC6, SONY and PANASONIC), also i replace the hex code "e0e09966" with all of what i got on one state of my AC Beko remote control.
My ESP is node mcu v1
Espeasy version R108, with IRTX plugin
IR transmitter connected to D7 (GPIO-13) then to 4 resistors of 390 ohm in parallel to get around 100 ohm then to the ground.
The output of IR transmitter detected by my camera normally when hitting the command in browser.
Please help me to understand my problem, maybe my codes is not classified or consider in designing IRTX plugin, so if someone help me to add the code to the plugin just for the on/off action.
Thank you in advance for your time.
Beko Air Conditioner Remote control codes
Re: Beko Air Conditioner Remote control codes
Hi, I am having the same problem. Did you resolve the problem?
Users browsing this forum: No registered users and 94 guests
