hi
i am trying to set NTP time in my esp. But the time offset is not accepting 5.30 which india gmt time and rounding it to 5.
so i am getting the wrong system time.
please advice
how to set time offset to india time gmt 5.30:::SOLVED:::
Re: how to set time offset to india time gmt 5.30
Current ESP Easy build has no support for timezone offsets other than whole hours. This will be fixed in R112 where the offset can be set in minutes. Then you would have to enter the value 330.rajbadri wrote:hi
please advice
R112 is now available on github. You can use it if you can compile your own builds. Else you have to wait until we launch the next stable...
works perfectly
one more question can we use system time in rules. please give example
Thanks again
works perfectly
Thanks again
there are explanations for "time".
http://www.esp8266.nu/index.php/Tutorial_Rules#Time
if it is that, what you mean with "system time" ?!
(if the thread is solve, may you kindly change the topic of your first post to "SOLVED: ..."?
Users browsing this forum: No registered users and 102 guests
