Reboot rule
Reboot rule
How should rules esp to restart t every day at 23.30? Please example
Re: Reboot rule
did no ttried myself, but maybe as a rule:
On Clock#Time=All,23:55 do // every day at xx.xx hours do ...
reboot
Re: Reboot rule
On Clock#Time=All,23:30 do
reboot
Is that right?
Re: Reboot rule
looks good. dont know if it will work.
the command reference is new from the developer...
addition: should work, as the reference-page says:
The internal commands can only be used from Serial or Rules engine.
If you want to use internal commands using HTTP/MQTT,
setup an event within the rules section and remotely launch the "event" command.
Users browsing this forum: Ahrefs [Bot] and 100 guests
