I'm working on a little device to give to a friend of mine. I built it and it works great.
I brought it outside of my network and I see the ESP_0 device on wifi and connect to it. After that I cannot pull up the page that let's you assign the network it should join. I tried yahoo.com thinking it would bounce me to the correct page, but no luck. Is there something other I should be doing?
To recap, the device is on my home network and works just fine, but now I can't figure out how to get it to join a new network. Any help is greatly appreciated!
Can't load config webpage after connecting
Re: Can't load config webpage after connecting
Hi !
Connect to your network, delete the SSID in the configuration and submit the changes, move the device to your friend and you should see the Access Point from the ESP for setting up the correct Wifi network ...
regards
Dominik
Dominik
Users browsing this forum: No registered users and 38 guests
