I'm quite new to ESPEasy but I've some experience using ESP8266/Wemos module for home automation system.
reading about this firmware wanted to test it if it can fits my need but I'm stuck even before starting
Step done so far:
1) Download ESPEasy 120
2) installed libraries in Arduino IDE
3) Compile and upload, all OK
4) connect to ESP_0 SSID with my tablet, using default password in the sketch (configesp)
5) Got the page at 192.168.0.4 where I select my WiFi SSID, enter my password
6) got a screen telling "ESPEasy configured, device IP is 192.168.1.105"
That's so far, from this point no way to connect to the ESP for config; I see that IP in my router but from any browser, any pc/tablet I have it does not accept connection.
I tried to completely erase the module, reflash with 108, back 120, then 134, back 120, every time same story.
Being fed up I took a brand new Wemos (I've bunch of them) tried and... same story; just to make sure I'm not faceing bad Myrphy's law, took a 3rd module but situation did not change.
I took the same 3 modules and flashed with different sketches I use in my system and they all works just fine.
Conclusion is I'm doing somethign weird with ESPEasy or I do miss somethign very, very stupid... Anyone that can help?
Wemos D1 Mini - cannot connect after 1st boot
Re: Wemos D1 Mini - cannot connect after 1st boot
Just to add that on the serial after the first config of SSID I see the ESPEasy feedback of boot, then just a line time to time telling me boottime and memory.
I cannot even send commands via serial as the device is not reacting at all...
and Arduino serial Monitor to work.
Wifi : connected or not ?
sorry my English is limited !
No worries, yes it's same as yours beside I don't have EVENTS.
It connects, init I2C, Book=OK and Normal Boot; then it starts to print out just boot time and memory.
I tried to send commands via serial but no reaction, I cannot reach it on the web (I see it in the router IP mapping so he got IP via DHCP) but the webpage goes timeout.
No need to say I tried HTTP command and they all go timeout I'm really lost!
And your IP (192.168.1.105) on Web browser
you have nothing ?
no main page ?
you have nothing ?
no main page ?
hi, I think I understood that problem is generated by one of the access point I use regularly.
with my sketches I am able to connect to those AP but not with ESPEasy apparently (it connects but does not communicate).
I swtiched to the 2nd floor AP and by magic now all works!
I've no explanation to the phenomena but it's there and repeatable...
Anyhow problema is Solved even with workaround
Users browsing this forum: Ahrefs [Bot] and 29 guests
