feature request: Uptime in days : hours : minutes only on the web page
hvdwolf
#1 Post by hvdwolf » 21 Oct 2016, 21:36
Currently the uptime on the Main webpage is in minutes. With an Esp Easy up for multiple days this becomes an "unreadable" number.
I found a reference to uptime in Misc.ino, and in webserver.ino
I would like to have this uptime in days : hours : minutes (or days / hours / minutes or whatever)
I'm a moderate python programmer, not a C programmer but I found a handy snippet on the internet for seconds conversion which I "converted"
int minutes= wdcounter/2;
int days=minutes/1440;
minutes=minutes%1440; /* minutes now less than a day */
int hrs=minutes/60;
int minutes=minutes%60; /*minutes less than an hour*/
And then something like
printf("D:H:M=%d:%d:%d\n",days,hrs,minutes)
And that's about the limit for my C knowledge :)
Could someone implement this if there are more in favour of this?
hvdwolf
Re: feature request: Uptime in days : hours : minutes
#2 Post by hvdwolf » 22 Oct 2016, 19:45
After all I wrote a patch myself and I have it now in test which does what I want. I let it run for 24+ hours to see how it behaves and then I will do a pull request.
f-fish
#3 Post by f-fish » 23 Oct 2016, 14:44
hmm not sure about wanting this as a default option .... maybe an option.
It is easy to work with minutes for both reporting and passing data onto something like domoticz not to mention using 1 unit in rules.
Did you check what the extra load is with your code enabled?
This might be a cosmetic change that could eat into low power requirements.
Later Ferdie
hvdwolf
#4 Post by hvdwolf » 23 Oct 2016, 20:50
f-fish wrote:hmm not sure about wanting this as a default option .... maybe an option.
It might indeed be better to make it an option via Tools->Advanced, but as I mentioned in the first post: I'm not a C programmer.
The extra load is nihil. I tested one of my nodemcu's and there is no additional load or is is below or around 1%
hvdwolf
#5 Post by hvdwolf » 23 Oct 2016, 22:53
And by the way: It is only on the webpage!
The time as used by Misc.ino and ESPEasy.ino for the log and as sysinfo device is still in minutes. So whatever system you use: domoticz, pimatic, some MQTT, etc. , you will still get minutes.
I didn't change that on purpose as it would change the interface. I only touched the web page.
f-fish
Re: feature request: Uptime in days : hours : minutes only on the web page
#6 Post by f-fish » 24 Oct 2016, 18:58
Ok so just webpage display ... hmmm that would actually be cool.
Later Ferdie
Users browsing this forum: Bing [Bot] and 98 guests
