Control of the relay when clicking the button (without network)
kostasoft
#1 Post by kostasoft » 31 Oct 2016, 20:12
Hi, everybody!
My device - Sonoff from Itead
Pinouts:
gpio0 - Button
gpio12 - Relay
gpio13 - Led
How to me to make that when clicking the button the relay switched?
And that it worked only by means of the standard program in a firmware that it was possible to include or turn off manually the light in the absence of the Internet or Wi-Fi of a network in particular.
dlefol
Re: Control of the relay when clicking the button (without network)
#2 Post by dlefol » 01 Nov 2016, 21:07
If I understand well what you're trying to do, you need to set up a rule as detailed in this post:
viewtopic.php?f=2&t=1867&p=8627&hilit=s ... ules#p8627
raptor
#3 Post by raptor » 02 Nov 2016, 15:22
Hi, kosta!
First go to Tools->Advanced and enable Rules (click on Rules checkbox).
Then go to Devices and cerate switch input like here:
Then go to Rules tab and paste this code:
on switchon do
gpio 12,1
gpio 13,0
inputswitchstate 0,1
on switchoff do
gpio 12,0
gpio 13,1
inputswitchstate 0,0
on Switch#switch do
if [Switch#switch]=1
event switchon
event switchoff
Submit and reboot!
Test. This setup works for me.
For more info about rules you can see the link which dlefol give you and this http://www.letscontrolit.com/wiki/index ... rial_Rules
Regards from Bulgaria.
raptor
kostasoft
#4 Post by kostasoft » 02 Nov 2016, 15:27
Many thanks! I understood everything.
javier77
#5 Post by javier77 » 04 Nov 2016, 15:16
Hi, i am a newbie with this and i am trying to do this same project to start. The button needs to be wired to gnd and the positive to gpio0? Thanks in advance!
raptor
#6 Post by raptor » 05 Nov 2016, 17:41
Hi, javier77!
If your device is Sonoff you don't need to wire the button! The button is already connected to gpio0. You need to make the settings which you can see in my previous post.
raptor
javier77
#7 Post by javier77 » 05 Nov 2016, 20:39
raptor wrote:Hi, javier77!
I am trying this on a NodeMCU D1 mini using an arduino relay module and a push button.
Thanks in advance.
Javier
raptor
#8 Post by raptor » 08 Nov 2016, 12:19
Unfortunately, I can't help you. I tried this only with Sonoff device.
raptor
gambi
#9 Post by gambi » 24 Nov 2016, 20:11
raptor wrote:Hi, kosta!
on switchon do
gpio 12,1
gpio 13,0
on switchoff do
gpio 12,0
gpio 13,1
on Switch#switch do
event switchon
event switchoff
Submit and reboot!
Hello Raptor, button works without network ?
FranckkyDoo
#10 Post by FranckkyDoo » 26 Mar 2017, 20:51
javier77
Yes
Positive to GPIO and gnd to ground
Zeric
#11 Post by Zeric » 30 Mar 2017, 01:02
This is all I have for my sonoff's:
On button#switch do // when button is pressed, toggle the relay
if [button#switch]=1
gpio, 12, 1
gpio, 12, 0
---Device Settings---
Device: Switch input
Delay: 0
IDX/Var: [what ever you need, I just use 1]
1st GPIO: GPIO-0
Switch Type: Switch
Switch Button Types: Push Button Active Low
Pull Up, Inversed, Send Boot State, Send Data - unchecked
Value Name 1: switch
danmero
#12 Post by danmero » 11 May 2017, 01:25
Only related , I set this configuration to be able to cycle the relay
on System#Boot do  / Set boot options
  gpio,12,1
on pushbutton#Switch=0 do  / On push button call event/function cycle
 event cycle
On Clock#Time=MonTueFri,03:53 do  / cron like job
 event cycle
on cycle do             / set gpio, start timer
 gpio,12,0
 gpio,13,0
 timerset,1,15
on Rules#Timer=1 do / on time expire reset gpio
 gpio,12,1
 gpio,13,1
Regards,
