Sonoff Wifi 5-pin LED control
I've gor my Sonoff flashed (147) and under 2-way control with Domoticz and some Rules.
The relay switches, and the LED goes on and off as required.
However, the LED, even when off, switches back on whenever the Sonoff sends any data back to Domoticz, e.g. RSSI.
If the LED is already on, it blinks!
Is this something hardwired into the device?
Domoticz, Sonoff, ESP32
Re: Sonoff Wifi 5-pin LED control
Post your rules!
Rules as requested.
SW0 = Push switch GPIO-0
Relay, State = GPIO-12 and its Value
on TurnOn do
if [Relay#State]=0
gpio,13,0
gpio,12,1
inputswitchstate 0,1
on TurnOff do
if [Relay#State]=1
gpio,13,1
gpio,12,0
inputswitchstate 0,0
on Toggle do
event,ToggleRelay
on SW0#Switch=1 do
event,ToggleRelay
on ToggleRelay do
if [Relay#State]=1
gpio,13,1
gpio,12,0
gpio,13,0
gpio,12,1
On System#Boot do //When the ESP boots, do
timerSet,1,10 //Set Timer 1 for the next event in 10 seconds
On Rules#Timer=1 do //When Timer1 expires, do
SendToHTTP RaspberryPi,8080,/json.htm?type=command=switchlight&idx=2313&switchcmd=Off
Pulse,13,0,500
gpio,12,0
Remove all lines with 'inputswitchstate x,y', try again and post your results please.
Hi Data,
Thanks, but I'm sure that the LED is also controlled by the main ESP code, overriding my settings.
I have had a look in the code.
The function void statusLED(boolean traffic) in Misc.ino is called from several places.
It certainly appears to make the blink I noticed when device data is sent to Domoticz and the LED is already on.
Also, if Wifi is connected, the LED state is set LOW which I guess is ON.
Have you made any changes on the GPIO page?
I have the same setup as you do but have not this issue.
Hi Data,
Thanks for pointing me in the right direction!
In Hardware, I had set Wifi Status Led: to 13.
Setting it blank fixes it.
Hello i am new in sonoff esp things anf might have killed my firt one
It would de helpfull to see what you have exactly done in all menues of the espy easy pages when flashing the sonoff to R120/147
I think and hope most people will have this first
pressing the button and switching the relais with status LED
sincerly
Michael
sincerly
Michael
