upload espeasy with arduino, no AP
i am using a nodemcu v3 to tryout espeasy.
I downloaded the latest arduino, 1.8.1, moved the libraries to arduino folder.
I opened the sketch, compile and upload it. Everything ok
in serial monitor i see this:
INIT : Booting Build nr:120
WIFI : Connecting... 1
WIFI : Connected!
INIT : I2C
INIT : Boot OK
INIT : Normal boot
WD : Uptime 0 ConnectFailures 0 FreeMem 28904
WD : Uptime 1 ConnectFailures 0 FreeMem 28872
WD : Uptime 1 ConnectFailures 0 FreeMem 28840
But, i am not seeing a new AP, or when i enter my own network settings, i don't see it connect to my own network.
WIFI : Connected!
INIT : I2C
INIT : Boot OK
INIT : Normal boot
Re: upload espeasy with arduino, no AP
Try in the serial monitor this command: settings
So, did you eventually changed the standard WiFi settings in the sketch to your real settings? Then it just connects to your network and doesn't provide an AP.sander815 wrote: INIT : Booting Build nr:120
WIFI : Connected!
INIT : I2C
INIT : Boot OK
INIT : Normal boot
I tried Both. Both say connecties, but i dont see it in my router as connected
i tried again with latest, opened in arduino, change nothing, compile and upload, but no AP.
i am using this esp8266:
https://www.aliexpress.com/item/V3-Wire ... 0.0.m844M9
and my settings:
i don't see an AP, nor do i see it on my connected devices, or can i ping the ip
and my settings:
#define DEFAULT_NAME "newdevice" // Enter your device friendly name
#define DEFAULT_SSID "TomatoRAF2" // Enter your network SSID
#define DEFAULT_KEY "mypass" // Enter your network WPA key
#define DEFAULT_SERVER "192.168.1.137" // Enter your Domoticz Server IP address
#define DEFAULT_PORT 8080 // Enter your Domoticz Server port value
#define DEFAULT_DELAY 60 // Enter your Send delay in seconds
#define DEFAULT_AP_KEY "configesp" // Enter network WPA key for AP (config) mode
#define DEFAULT_USE_STATIC_IP false // true or false enabled or disabled set static IP
#define DEFAULT_IP "192.168.1.138" // Enter your IP address
#define DEFAULT_DNS "192.168.1.1" // Enter your DNS
#define DEFAULT_GW "192.168.1.1" // Enter your gateway
#define DEFAULT_SUBNET "255.255.255.0" // Enter your subnet
ping 192.168.1.138
Pinging 192.168.1.138 with 32 bytes of data:
Reply from 192.168.1.1: Destination host unreachable.
You have default ip settings as false therefore it will probably default to the 192.168.4.x subnet
Change it to true and recompile.
I dont think an AP will be available as the settings have been modded.
ESP32, Arduino's,Raspberry Pi's, ESP8266's, Nextion's, Sonoff's, LightWaveRF's, RFXCom 433, and a headache
And a HackRF One, as a present to myself.
you better let the DHCP provide an ip to your ESP device, when connected to ur AP. After doing 'settings' in serial monitor, the ip will be shown
Unless you are like me and dont have a massive house therefore needing dhcp is not an option..
You dont have mulit-subnet capabilities by the look of it.
For me, a static IP. The choice is yours.
no, i cannot get it to work
i also tried flashing with esptool.exe
I assume i should see an AP now, when i read the instructions?
I am running the nodemcu from usb power, i assume that is correct?
@echo off
esptool.exe -vv -cd nodemcu -cb 115200 -cp COM4 -ca 0x00000 -cf ESPEasy_R120_4096.bin
pause
could it be a hardware mismatch with my main router and the esp8266 hardware?
I have 2 routers, one ziggo connectbox(hardware unknown) and an TP-Link archer C7.
When i enter the Archer C7 wifi settings its working fine, when i enter the ziggo connectbox wifi settings, i cannot get access
fixed it. Esp8266 was ot in dhcp list and wireless connected devices, but a network scan revealed its ip. Very strange
Users browsing this forum: Ahrefs [Bot] and 102 guests
