ESPEASY Devices
ESPEASY Devices
im new in EaspEasy and there is a problem.
There is no Relay, LED.... in the Devices List. I have flashed R120 and there are 33 Items in list.
Anything wrong?
Anything wrong?
Re: ESPAESY Devices
Look here:nettworker wrote:Hello,
Anything wrong?
http://www.letscontrolit.com/wiki/index ... dware_page
Re: ESPEASY Devices
In the device list isn't a led or relay. How to use a led or relay look in the wiki.nettworker wrote:
Re: ESPEASY Devices
I saw a MAX 6675 Thermocouple Device here: viewtopic.php?f=2&t=2036
That isn't in my List. Therefore is thought, i have a Problem....
Re: ESPEASY Devices
Ever heard the acronym GPIO?
If it is only on/off, you simply make use of one of your available GPIO (General Purpose Input Output) Pins.
Re: ESPEASY Devices
I Know what GPIO's are, thanks
But i am learning how ESPEASY works and how it communicate with Domoticz.
Re: ESPEASY Devices
some actuators need configuration - only those actuators are found in the device list, the IR sending LEDs for example.
A relay or a LED do not need any configuration besides the hardware connection to a GPIO pin. There is no device to configure.
They can be driven just by a command like http://<ip-adress of ESPEasy-device>/control?cmd=gpio,x,[1|0]
where "x" is the GPIO port and 1 or 0 set the port to high or low
How to control a relay via Domotics is shown in the Wiki:
http://www.letscontrolit.com/wiki/index.php/Relais
I can't say much about that as i'm using FHEM.
Re: ESPEASY Devices
Hy, I flashed my sonoff with espeasy r120. After installing it in fhem(on a raspBerry Pi) i get no the readings of the gpio. Setting the switch is possible. Why do the sonoff do not send readings (f.ex. relay)? Whats wrong?
Re: ESPEASY Devices
ManS-H
Try Switch Input
And take a time in the forum to read a little
That useful!!!
Try Switch Input
That useful!!!
Re: ESPEASY Devices
What do you mean? I only give the poster advise to read the wiki.FranckkyDoo wrote:ManS-H
Try Switch Input
That useful!!!
Users browsing this forum: Bing [Bot] and 41 guests
