I m using a Nodemcu with Bme280 esp easy mega v2.0.0-dev7.
Have connect Bme280 sda to D3 and scl to D4 .
I got wrong temperature difference +6 degrees celsius .
I read if using D3 and D4 no need of resistors.
Any suggestions ?
Nodemcu Bme280
Re: Nodemcu Bme280
BME280 might be faulty? Try to calibrate it to find out or simply use %value%-6 as formula.
Re: Nodemcu Bme280
Thanks grovkillen.grovkillen wrote: ↑18 Apr 2017, 19:33 BME280 might be faulty? Try to calibrate it to find out or simply use %value%-6 as formula.
I m using the formula %value%-6.
I thought I was doing something wrong .
Re: Nodemcu Bme280
This tgemperature deviation is most likely caused by self heating, heating by surrounding electronics and insufficient air flow.
https://ae-bst.resource.bosch.com/media ... 001-11.pdf
page 10
page 10
Users browsing this forum: No registered users and 68 guests
