i'm trying to get something out of a esp-12f module. can i connect this with a regular serial port on an older computer?
should it work with a regular usb->serial port adapter?
i can't seem to get anything out of it or program it. do i need a *special* serial adapter or something?
serial to esp-12f
Re: serial to esp-12f
you need a usb-to serial adapter with 3.3 V like this one:
https://www.aliexpress.com/item/6Pin-US ... 0.0.HqMHss
or
https://www.aliexpress.com/item/6in1-US ... 0.0.HqMHss
... but for starters i would suggest a esp8266 board with buildt in usb-to-serial like the wemos d1 mini:
https://www.aliexpress.com/item/D1-mini ... 01036.html
or
shortly after i posted this i ended up coming to the understanding that there was a big difference between rs232 and ttl. i hopped over to microcenter and got a ttl serial adapter on my way home from work. i was able to successfully flash it within minutes after beating my head against the wall the past 2 days not being able to communicate with this module
all is well
all is well
Users browsing this forum: Google [Bot] and 31 guests
