after power off/on nodemcu can not connect to wifi network
hi friends. i have use some nodemcu for espeasy, but after power off/on house most of node can not connect to wifi network and i can not use this. . .
Re: after power off/on nodemcu can not connect to wifi network
You probably should check what GPIOs are used. Some setups are causing problems on reboot.
https://www.letscontrolit.com/wiki/inde ... figuration
no , i am just use D3 and D4 for I2Cgrovkillen wrote: ↑17 Jun 2017, 15:42You probably should check what GPIOs are used. Some setups are causing problems on reboot.
You could try some other since those two need to be HIGH on boot (as stated on the wiki). D1 and D2 are recommended I2C ports.
in wiki told me use D3 & D4 for I2C PMEgrovkillen wrote: ↑17 Jun 2017, 18:55 You could try some other since those two need to be HIGH on boot (as stated on the wiki). D1 and D2 are recommended I2C ports.
https://www.letscontrolit.com/wiki/inde ... niExtender
That is not correct, I've updated the wiki for that device.
oh thank you , i will change this tomorrow.
now i have just one problem . can you help me about this ?
https://www.letscontrolit.com/forum/vie ... 4&start=10
if you can help me about this i am very thank you
can i send state of EXTGPIO (state of relay) to controller directlly ? if yes how ? and if no , is this possible i can add this or espeasy team add this to new update?
Users browsing this forum: Ahrefs [Bot], Google [Bot] and 32 guests
