Toggle a relais / relay for 1 second over MQTT?
Hi guys:
I'm relatively new to espeasy, and must say it is really great.
I've gone through the forum in hopes of being able to control my garage door over MQTT, but can't seem to get a rule right to pulse / toggle a relay for 500ms, or even 1 second to simulate a button press. I am running espeasy v2.0.0-dev10, on a Wemos D1 Mini with a relay connected to GPIO 5. If I issue an http command as in:
http://192.168.0.xxx/control?cmd=Pulse,5,1,500
The relay pulses quickly to simulate a pulse / button press on the garage control, but I can't seem to get this going with any rules over MQTT. I also have a reed switch connected on GPIO 12 also to indicate status of the door, ( either opened or closed ), and have seen a few posts such as this one:
https://www.letscontrolit.com/forum/vie ... 9&start=20
and have tried the following rule, but it will not pulse the relay with the v2.0.0-dev10 code:
on button#state do
if [relay#state] = 0
GPIO,12,1
GPIO,12,0
on relay#state do
if [relay#state] = 1
gpio,13,0
gpio,13,1
on relay#state do
Publish /sonoff2/gpio/12,1
Publish /sonoff2/gpio/12,0
can anyone please help with a rule to pulse a relay for 500ms or 1 second to simulate a button press?
Thanks very much!
on button#state do
GPIO,12,1
GPIO,12,0
on relay#state do
gpio,13,0
gpio,13,1
on relay#state do
Thanks very much!
Re: Toggle a relais / relay for 1 second over MQTT?
Also, here are my devices:
on button#state do
if [relay#state]=0
Pulse,12,1,500
GPIO,12,0
on relay#state do
if [relay#state]=1
GPIO,13,0
GPIO,13,1
PS. I don't see a "button" as a device in the screenshot? It is somewhat hard to grip what you are trying to do here so please give as much information as possible. Some garage doors has the possibility to just add a switch which will just short two io. I don't think that need to be pulsed more than a reasonable time, this would do:
GPIO,12,1
Delay 1000
GPIO,12,0
Hi grovkillen. Thank you very much for your reply! Basically, what I am trying to do is connect a relay to my garage door button, inline with the existing two wires to simulate the press on the garage door opener, I have a relay on GPIO-5, and a reed switch on GPIO-12 that determines if the door is open or closed. Below is the screenshot of the devices, and how the relay is currently configured. I did try your code example without any luck. I am NOT using a sonoff device, but just a standard relay.
on button#state do
Thanks grovkillen. appreciated. Any idea what the code might look like based on the devices attached to pulse the relay momentarily for 500ms over MQTT? The following http command works great: http://192.168.0.145/control?cmd=Pulse,5,1,500
Just need to find a way or rule to get it to pulse when a 1 is received over MQTT
You can send that command over MQTT as well.
Topic
Payload (message)
Topic
<your_device_name>/cmd
Pulse,5,1,500
What I learnt moving to V2.0.0 is that you need to add 'MQTT Input' as a device to set a topic. And of cource Controller subscripe/publish if you want to have a feedback of the Relay-status. I use this little rule
to get this feedback. Hope this helps.on mqtt_relay#state do
if [mqtt_relay#state]=0
gpio,5,0
gpio,5,1
https://www.letscontrolit.com/wiki/inde ... _2.0.2B.29werner_g wrote: ↑10 Jul 2017, 13:08 What I learnt moving to V2.0.0 is that you need to add 'MQTT Input' as a device to set a topic. And of cource Controller subscripe/publish if you want to have a feedback of the Relay-status. I use this little ruleto get this feedback. Hope this helps.on mqtt_relay#state do
gpio,5,0
gpio,5,1
If your have set up the controller setting to subscribe to <unit name>/# you can send pretty much any command from this list:
https://www.letscontrolit.com/wiki/inde ... _Reference
Just use this topic: <unit name>/cmd
Work this payload/message: Pulse,5,1,500
I am wondering why this doesn't work here (PiDome MQTT):
the relay is not switching!
Controller Subscribe: any/set/WM/Relay01/#
Controller Publish: any/state/WM/%sysname%
Topic: any/set/WM/Relay01/cmd
payload: GPIO,5,1
Does this work?werner_g wrote: ↑11 Jul 2017, 18:50 I am wondering why this doesn't work here (PiDome MQTT):the relay is not switching!Code: Select all
Controller Subscribe: any/set/WM/Relay01/# Controller Publish: any/state/WM/%sysname% Topic: any/set/WM/Relay01/cmd payload: GPIO,5,1
payload: reboot
And you need the subscription topic to be a none default one?
If you subscribe to the default one:
And then send the <name of unit>/cmd with payload gpio,5,1 still doesn't work?
Just to try I mean...
%sysname%/#
quite funny, I tried several things, at least changing again to OpenHAB-MQTT and now it works like it has to do:
But still 'cmd Reboot' doesn't work. Not the showstopper, I'm happy it is now working the standard way without adding the device 'MQTT Import'Controller Subscribe: any/set/WM/Relay01/#
GPIO,5,1
Good that it works now. What version are you on?
v2.0.0-dev10
Users browsing this forum: No registered users and 95 guests
