i an using WEMOS D1 mini with actuell firmware (v 2 dev 11). I try to use the serial server while using tx/rx, no success. I only get messages ser2net connected / disconnected. I have changed the tx/rx lines for testing many times...
If i use the follwing plugin, my serial device is working. With this plugin the serial device must be connected via D7/D8, instead of tx/rx, but it works.
I got the plugin with a ready to use firmware, based on RC147.
Is there a chance to use the "normal" serial server ?
Or is there a chance to implement this plugin in official repostory ?
//#################################### Plugin 130: _P130_SSSRV ############################################
//################################ software serial server #########################################
#include <SoftwareSerial.h>
#define PLUGIN_130
#define PLUGIN_ID_130 130
#define PLUGIN_NAME_130 "Software Serial Server"
#define PLUGIN_VALUENAME1_130 "SwSerSrv"
#define BUFFER_SIZE_SW 128
boolean Plugin_130_init = false;
WiFiServer *ser2netServerSW;
WiFiClient ser2netClientSW;
//SoftwareSerial swSer(14, 12, false, 256); DEVKIT 1.0 for test...
// recive 14 --> D5 e transmit 12 --> D6 e invert e buffersize
SoftwareSerial swSer(13, 15, false, 256); // Wemos D1 Mini
boolean Plugin_130(byte function, struct EventStruct *event, String& string)
boolean success = false;
switch (function)
case PLUGIN_DEVICE_ADD:
Device[++deviceCount].Number = PLUGIN_ID_130;
Device[deviceCount].Type = DEVICE_TYPE_SINGLE;
Device[deviceCount].VType = SENSOR_TYPE_SINGLE;
Device[deviceCount].Custom = true;
Device[deviceCount].TimerOption = false;
case PLUGIN_GET_DEVICENAME:
string = F(PLUGIN_NAME_130);
strcpy_P(ExtraTaskSettings.TaskDeviceValueNames[0], PSTR(PLUGIN_VALUENAME1_130));
case PLUGIN_WEBFORM_LOAD:
char tmpString[128];
sprintf_P(tmpString, PSTR("<TR><TD>TCP Port:<TD><input type='text' name='plugin_130_port' value='%u'>"), ExtraTaskSettings.TaskDevicePluginConfigLong[0]);
string += tmpString;
sprintf_P(tmpString, PSTR("<TR><TD>Baud Rate:<TD><input type='text' name='plugin_130_baud' value='%u'>"), ExtraTaskSettings.TaskDevicePluginConfigLong[1]);
string += F("<TR><TD>Select pin, not used now:<TD>");
addPinSelect(false, string, "taskdevicepin1", Settings.TaskDevicePin1[event->TaskIndex]);
success = true;
case PLUGIN_WEBFORM_SAVE:
String plugin1 = WebServer.arg("plugin_130_port");
ExtraTaskSettings.TaskDevicePluginConfigLong[0] = plugin1.toInt();
String plugin2 = WebServer.arg("plugin_130_baud");
ExtraTaskSettings.TaskDevicePluginConfigLong[1] = plugin2.toInt();
SaveTaskSettings(event->TaskIndex);
success = true;
case PLUGIN_INIT:
LoadTaskSettings(event->TaskIndex);
int irPin = Settings.TaskDevicePin1[event->TaskIndex];
irPin =14;
if ((ExtraTaskSettings.TaskDevicePluginConfigLong[0] != 0) && (ExtraTaskSettings.TaskDevicePluginConfigLong[1] != 0) && (irPin != -1))
swSer.begin(ExtraTaskSettings.TaskDevicePluginConfigLong[1]);
ser2netServerSW = new WiFiServer(ExtraTaskSettings.TaskDevicePluginConfigLong[0]);
ser2netServerSW->begin();
//String tmp =String((ExtraTaskSettings.TaskDevicePluginConfigLong[1]),DEC);
//addLog(2,tmp);
Plugin_130_init = true;
success = true;
case PLUGIN_TEN_PER_SECOND:
if (Plugin_130_init)
size_t bytes_read;
if (!ser2netClientSW)
while (swSer.available()) {
swSer.read();
ser2netClientSW = ser2netServerSW->available();
if (ser2netClientSW.connected())
uint8_t net_buf[BUFFER_SIZE_SW];
int count = ser2netClientSW.available();
if (count > 0) {
if (count > BUFFER_SIZE_SW)
count = BUFFER_SIZE_SW;
bytes_read = ser2netClientSW.read(net_buf, count);
swSer.write(net_buf, bytes_read);
//swSer.flush();
net_buf[count]=0;
//addLog(LOG_LEVEL_DEBUG,(char*)net_buf);
uint8_t serial_buf[BUFFER_SIZE_SW];
size_t bytes_read = 0;
while (swSer.available() && bytes_read < BUFFER_SIZE_SW) {
serial_buf[bytes_read] = swSer.read();
bytes_read++;
if (bytes_read > 0) {
ser2netClientSW.write((const uint8_t*)serial_buf, bytes_read);
ser2netClientSW.flush();
serial_buf[bytes_read]=0;
//addLog(LOG_LEVEL_DEBUG,(char*)serial_buf);
ser2netClientSW.stop();
swSer.flush();
success = true;
return success;
regards
Klaus
