Speaker function ?
ILoveIOT
Speaker function ?
#1 Post by ILoveIOT » 02 Dec 2015, 11:29
Maybe its easy (don't know) to implement to have a speaker function so you get a acknowledge from Domoticz, with some different tones, for different functions.
http://<ESP IP address>/control?cmd=spk,<pin>,1-2-3 etc
ambassadoro
Re: Speaker function ?
#2 Post by ambassadoro » 03 Dec 2015, 14:28
Could be done with a piezo like this and pwm:
Ebaybuzzer.
ILoveIOT
#3 Post by ILoveIOT » 03 Dec 2015, 16:22
Yes,..this piezo buzzer (speaker) I mean, is it already working ?
ILoveIOT
#4 Post by ILoveIOT » 07 Dec 2015, 19:33
Thank you for the lead, http://192.168.50.194/control?cmd=Pulse,14,1,100 did the trick for me, single tone do, but it does the job ;)
With PWM you have to send a off command as well, pulse stops after 100ms, in this case.
Marteln
#5 Post by Marteln » 30 Sep 2016, 23:22
I add some code to _P001_Switch, now I can play tone with any frequency: http://192.168.3.57/control?cmd=tone,14,330,2000 - on port 14 play E1 two seconds.
and
Or play RTTTL melody: http://192.168.3.57/control?cmd=rtttl,14,Bach - Prelude In C Minor:d=8,o=5,b=180, c6, b, c6, p, g, g-, p, f, b, c6, p, d6, p, g, p, c6, b, c6, p, d6, p, f, g, g-, 4p, g, f, 4d-
moelski
#6 Post by moelski » 01 Oct 2016, 06:57
Hi Marteln,
can you share the code ?
regards
Dominik
Marteln
#7 Post by Marteln » 01 Oct 2016, 10:15
Here it is. There are two new function:
void play_rtttl(uint8_t _pin, char *p )
void tone(uint8_t _pin, unsigned int frequency, unsigned long duration)
and two if statements:
if (command == F("rtttl"))
success = true;
if (event->Par1 >= 0 && event->Par1 <= 16)
pinMode(event->Par1, OUTPUT);
char sng[1024] ="";
string.replace("-","#");
string.toCharArray(sng, 1024);
play_rtttl(event->Par1, sng);
setPinState(PLUGIN_ID_001, event->Par1, PIN_MODE_OUTPUT, event->Par2);
log = String(F("SW : ")) + string;
addLog(LOG_LEVEL_INFO, log);
SendStatus(event->Source, getPinStateJSON(SEARCH_PIN_STATE, PLUGIN_ID_001, event->Par1, log, 0));
if (command == F("tone"))
success = true;
tone(event->Par1, event->Par2, event->Par3);
In RTTTL definition is used character "#", but it must be encoded in URL, so I use "-".
_P001_Switch.rar
(3.51 KiB) Downloaded 123 times
Marteln
#8 Post by Marteln » 01 Oct 2016, 10:22
I needed a wireless doorbell. The first version was with the UM66, but it meant only one meody ...
tozett
#9 Post by tozett » 02 Oct 2016, 08:25
wonderful addition.
hi dev,
are you listening here?
can it go into the main development branch?
(or someone good in coding make a plugin? moelski? :mrgreen: )
:mrgreen:
Marteln
#10 Post by Marteln » 02 Oct 2016, 08:48
tozett wrote:wonderful addition.
hi dev,
:mrgreen:
Yes, it can. No problem.
moelski
#11 Post by moelski » 02 Oct 2016, 10:44
Hi tozett !
Working on my Candle Plugin ;)
But this is more an Actor and not a Sensor ...
But anyway ... Making a stand alone "tone" plugin should be straight forward ...
regards
Dominik
rol-rider
#12 Post by rol-rider » 02 Oct 2016, 14:37
Great idea,
I wanted to test,
_P001_Switch.rar
it does not compile.
296  log = String(F("SW   : GPIO ")) + String(event->Par1) + String(F(" Set PWM to ")) + String(webreq);
exit status 1
'webreq' was not declared in this scope
thank.
sorry I do not speak English!
sorry for my English ! i use google translat.
Marteln
#13 Post by Marteln » 02 Oct 2016, 15:35
rol-rider wrote:Great idea,
I wanted to test,
_P001_Switch.rar
exit status 1
thank.
Oh, sorry!
I sent older version :o
This is the correct.
_P001_Switch.rar
(3.5 KiB) Downloaded 130 times
rol-rider
#14 Post by rol-rider » 02 Oct 2016, 16:43
Thanks,
I still managed to use "tone"
in rules:
On BP#BP do
     tone,14,435,600
     tone,14,580,600
     tone,14,435,600
     tone,14,580,600
     tone,14,435,600
     tone,14,580,600
     tone,14,435,600
     tone,14,580,600
French police siren
but "rtttl" ???
I test the new file.
Marteln
#15 Post by Marteln » 02 Oct 2016, 17:10
rol-rider,
you have to replace "#" with "-" or urlencode string.
rol-rider
#16 Post by rol-rider » 02 Oct 2016, 18:20
Great ! it works !
this is the ":" I forgot!
http://192.168.0.3/control?cmd=rtttl,14:d=8,o=5,b=180,c6,b,c6,p,g,g-,p,f,b,c6,p,d6,p,g,p,c6,b,c6,p,d6,p,f,g,g-,4p,g,f,4d-
beautiful melody
Marteln
#17 Post by Marteln » 02 Oct 2016, 20:55
rol-rider wrote:Great ! it works !
beautiful melody
Correct syntax is : rtttl, pin,name_of_melody:duration,octave,beat,notes..........
Somewhere use ":" after beat, somewhere ","... I didnt try ":", maybe work, maybe not.
https://en.wikipedia.org/wiki/Ring_Tone ... r_Language
rol-rider
#18 Post by rol-rider » 03 Oct 2016, 00:16
ok, thank you for the clarification.
tozett
#19 Post by tozett » 03 Oct 2016, 14:03
hope this doku finds it way to the wiki ... ;)
psy0rz
#20 Post by psy0rz » 13 Feb 2017, 09:23
is this in the dev branch yet? or should someone make a pull request?
psy0rz
#21 Post by psy0rz » 17 Feb 2017, 00:33
I needed speaker support myself to build an Alarm system for my home. Needed the alarm to give audio feedback. (e.g. alarm enable/disable tones, window-open notification sounds etc)
I cleaned up the code (identation), and moved the functions to Misc.ino
Its avaiable in v1.1.0-beta7 in the testing plugin-set.
Edwin
kniazio
#22 Post by kniazio » 13 Mar 2017, 19:08
I have uploaded version dev6
https://github.com/letscontrolit/ESPEasy/releases
It is written in the description
Implemented speaker and tone functions from https://www.letscontrolit.com/forum/vie ... r&start=10
I get the message
Unknown or restricted command!
psy0rz
#23 Post by psy0rz » 14 Mar 2017, 00:07
Its in the testing plugin set. So you need the test or dev firmware version.
I just updated the wiki: https://www.letscontrolit.com/wiki/index.php/GPIO
kniazio
#24 Post by kniazio » 14 Mar 2017, 07:00
After being exchanged plugin _P001_Switch forum
https://www.letscontrolit.com/forum/vie ... ?f=4&t=343
melodies work
It seems that in the dev version 6 is a mistake
psy0rz
#25 Post by psy0rz » 14 Mar 2017, 10:34
kniazio wrote: 14 Mar 2017, 07:00 After being exchanged plugin _P001_Switch forum
melodies work
uuuhh ...what do you mean? :)
kniazio
#26 Post by kniazio » 14 Mar 2017, 11:17
psy0rz wrote: 14 Mar 2017, 10:34
melodies work
I mean that with version dev6 wrote melodies that have been added.
These tunes do not work
I see that RTTTL code is added to the plugin misc.ino but it did not work.
I swapped the old plugin _P001_Switch.ino and melodies work
I did it according to the description of the forum
post 7
kniazio
#27 Post by kniazio » 14 Mar 2017, 12:24
After sending the command:
I get the answer:
In contrast, using a modified plugin _P001_Switch.ino
I get the answer:
"log": "rtttl,14:d=8,o=5,b=180,c6",
"plugin": 1,
"pin": 14,
"mode": "output",
"state": 0
psy0rz
#28 Post by psy0rz » 14 Mar 2017, 13:24
You have to use the correct binary.
If you have 4096Mb flash use: ESPEasy_v2.0.0-dev6_dev_4096.bin
If you have 1024MB flash use: ESPEasy_v2.0.0-dev6_dev_1024.bin
Notice the _dev_ at the end, that means: All the plugins that are in testing and development state.
kniazio
#29 Post by kniazio » 14 Mar 2017, 17:56
psy0rz wrote: 14 Mar 2017, 13:24 You have to use the correct binary.
I do not use ready .bin file alone compile
In the previous post I explained to guess exactly what's going on
psy0rz
#30 Post by psy0rz » 14 Mar 2017, 18:01
ah you compiled it yourself. what did you use to compile it, Arduino IDE or platformio?
Edwin
kniazio
#31 Post by kniazio » 14 Mar 2017, 19:36
psy0rz wrote: 14 Mar 2017, 18:01 ah you compiled it yourself. what did you use to compile it, Arduino IDE or platformio?
Edwin
Arduino IDE
psy0rz
#32 Post by psy0rz » 14 Mar 2017, 21:20
I still have to adjust the tutorials for that.
If you compile it now, it will not comile the TEST and DEV plugins.
if you add this to ESPEasy.ino it will work, without the other adjustments you made:
#define PLUGIN_BUILD_DEV
#define PLUGIN_BUILD_TESTING
kniazio
#33 Post by kniazio » 15 Mar 2017, 06:39
I do not understand what you mean.
I believe that in the file Misc.ino is an error, and therefore tunes do not work.
Why work with a file _P001_Switch.ino?
_P001_Switch_z melodyjkami.rar
(3.5 KiB) Downloaded 88 times
psy0rz
#34 Post by psy0rz » 15 Mar 2017, 09:37
I fixed the tutorial and source code.
Use v2.0.0-dev7 , follow this tutorial: https://www.letscontrolit.com/wiki/inde ... are_Upload
make sure you enable the testing plugin set. (in espeasy.ino)
Edwin
kniazio
#35 Post by kniazio » 15 Mar 2017, 11:05
psy0rz
#36 Post by psy0rz » 15 Mar 2017, 11:26
strange..i'm using that version and it works here.
