Arduino IDE
Speaker function ?
Re: Speaker function ?
I still have to adjust the tutorials for that.
If you compile it now, it will not comile the TEST and DEV plugins.
if you add this to ESPEasy.ino it will work, without the other adjustments you made:
#define PLUGIN_BUILD_DEV
#define PLUGIN_BUILD_TESTING
I do not understand what you mean.
I believe that in the file Misc.ino is an error, and therefore tunes do not work.
Why work with a file _P001_Switch.ino?
- _P001_Switch_z melodyjkami.rar
- (3.5 KiB) Downloaded 244 times
I fixed the tutorial and source code.
Use v2.0.0-dev7 , follow this tutorial: https://www.letscontrolit.com/wiki/inde ... are_Upload
make sure you enable the testing plugin set. (in espeasy.ino)
Edwin
Edwin
Unknown or restricted command!
Users browsing this forum: No registered users and 56 guests
