How i can compile the newest source code with arduino Ide in order to load in ESP8266??
With the newest source code i have a lot of errors... I can compile older R148 realease without problems.....
Is it not popsible? Do we need platformio to do it?
How to compile with arduino - SOLVED WORKING
Re: How to compile with arduino
The newer sources of ESPEasy 2.0.0 use modified or newer libraries.
If you just swapped the ide to newer sources it will not compile without errors.
Search the wiki for a tutorial, i"d suggest to make a second clean installation of the ide
to compile newer sources.
Thanks a lot!!!
I have it working again after installing all on a clean portable install....
THANKS THANKS THANKS!!!!
Users browsing this forum: Google [Bot] and 97 guests
