no wifi (esp_0) after flash on S20
Re: no wifi (esp_0) after flash on S20
Either Platformio or Arduino IDE.
You may use the flash download tool from espressif, the manufacturer of the ESP8266.
--> https://espressif.com/en/support/download/other-tools
Some how to about using that tools can be found at instructables:
http://www.instructables.com/id/ESP-12F ... -Firmware/
Please be aware that using these flash tools is somewhat more complex.
Hi all, I had to register again to join this discussion I haven't been online since the update of the forum.
But I still can't get my s20 to work.
I flashed my s20 several times with different tools in dio mode.
with arduino ide, the flash tool from espressif, nodemcufirmware programmer.
flashing goes ok all the time.
The voltage is 3.3 volts and stable.
But no wifi ap after reboot, the s20 stays death.
I don't know what to try more.
Any ideas? I hope somebody can help.
Do you get any serial feedback when trying to reboot?
After flashing connect via arduino ide serial monitor.
I had the same problem with sonoff. When connected to serial it showed numbers running up and after a minute or so it booted into ap mode
I too have this problem trying to flash a UK S20.
It's board version S20_EU_V1.3.
Each time I flash, it just completely locks up.
Upload using the latest included FlasgESP8266.exe - uploads - fails
I've also tried TASMOTA using Atom - works as it should
Compiling the Espeasy source in ATOM - uploads once I change board rate to 115200 - fails
Using Espressif Flash tool - fails to upload
Getting quite frustrating!
All suggestions welcome.
Adam
Adam
[Solved?]Re: no wifi (esp_0) after flash on S20
After much googling and messing around, I have made it work.
It turns out the Sonoff design changed earlier this year to use an ESP8285 instead of the ESP8266.
Selecting the ESP8285 flash and it now loads correctly!
Hope this helps
Adam
Hope this helps
Adam
That's great finding there Adam! I will try add that to the wiki.
Thank you very much for the information!
It did not send any data on the serial lines, it was completely death.
On the esp chit itself is just printed that it is a 8266.
But I flashed it with the 8285 settings and now everything works fine!
Thanks a lot!
I'm happy that I can use the s20 again.
Thanks a lot!
Mate, you saved my sanity. THANK YOU!!!bobbybeans wrote: ↑09 Oct 2017, 19:38 sweet lord baby jesus! i got it to work with esp easy r147. I flashed it like normal but you brought up a good point of it needed to be flashed in "din". This however did not work. so i just went down the line and tried every single option I set SPI mode to "DOut" and it worked. the rest of them I tried didn't work.
After trying: R_147, Mega_2.0 several times, using Arduino IDE, then the delivered flasher, trying both QIO and DIO several times. It always flashed as I am used to, but after plugging it in, just dead S20.
DOut WORKS!
My boards are brand new S20_EU_V1.3 2017-2-16 with UK socket and still has ESP8266 on board. First thing I checked...
My S20 is the 1.3 EU version. I've also flashed it several times using different versions (Espeasy R120 and R148) and tools (esptool.exe and Arduino IDE), and although the process seeemed to go fine, the access point did not show up after rebooting.
I was starting to think that I had a faulty unit until I found this thread. I finally got it working downloading ESPEasy_v2.0.0-dev12 and flashing it using FlashESP8266.exe and selecting the 8285 firmware (ESPEasy_v2.0.0-dev12_normal_8285.bin).
Thank you, Adam!
Thank you, Adam!
- dynamicdave
I've got the same problem trying to flash a couple of S20 Sonoff.
Never done this before!!
Tried all sorts of flashers/loaders and various firmware files.
I received 5-off Wemos D1 Mini devices in the same package as the S20s and they flashed with no problem at all.
The markings on the PCB says S20-EU-V1.3 date 2017-2-16
The chip has engravings saying it is an ESP8266.
Any help/guidance/devine wisdom would be much appreciated.
Cheers from David
Cheers from David
You could try flashing it using 8255.
- dynamicdave
I've used SonOff switches in the past, but never used the S20 before!!
It seems as if the S20 has been flashed, but the ESP_easy_0 wifi never shows up.
Cheers from David
Cheers from David
- dynamicdave
The markings on the chip says it's an ESP8266.
What are you suggesting?
1. Try flashing it with firmware for 8255, or
2. Flashing with the ESP8255 flasher tool
Reading all the above messages it sound as if lots of people are having this problem.
My S20s are for the UK mains plugs with code; S20-EU-V1.3 dated 2017-2-16
Any help/suggestions would be appreciated as I'm pulling my hair out!!!
Cheers from David
My suggestion is to flash it using the bin file for ESP8285 (sorry 'bout that typo) since the ESP8285 is equal to the ESP8266 except that the 8285 has 1MB built in mem.
The newer Sonoff seems to need other flash settings active, which the bin file for ESP8285 seems to have (please correct me if I'm wrong here...).
- dynamicdave
Thanks for your swift response.grovkillen wrote: ↑01 Dec 2017, 10:48 My suggestion is to flash it using the bin file for ESP8285 (sorry 'bout that typo) since the ESP8285 is equal to the ESP8266 except that the 8285 has 1MB built in mem.
I'll try it later today.
This morning I had a couple of SonOff Touch Switches arrive - it will be interesting to see if I can flash them - I think they do have ESP8285 chips inside them.
Cheers from David.
Regarding the Touch you should follow the wiki. They are covered with a guide on how to flash etc.
- dynamicdave
BRILLIANT news to report to you.grovkillen wrote: ↑01 Dec 2017, 12:39 Regarding the Touch you should follow the wiki. They are covered with a guide on how to flash etc.
Thanks to your suggestion, I've managed to get both S20 working.
Kind regards from David.
Great! Happy to have helped.
wow didn't know this thread was still going! yeah I can confirm mine has 8266 on it but the new ones I will try the 8285
I am a new user. I just wanted to say that I had the same symptoms as described here. Flashing always successful, but later AP ESP_0 is missing. I tried different versions of Mega, 2.0, R120 .. - always the same result - wifi does not appear. Different flaschers. Finally, I used ESP Easy Flasher created by Grovkillen and the first time I was able to program my Sonoff TH10 v2.0. I have marked options:
"Post flash action",
"Halt app before flash"
"Force D-OUT"
I chose the firmware for ESP8285 - this chip is in Sonoff TH10 / 16 v2.0
I entered the details of my WiFi and IP address.
After pressing the "Flash ESP Easy FW" button my Sonoff was programmed. I unplugged Sonoff's power and plug it in again. I pressed the continuation button that appeared in the ESP Easy Flasher program. Over the serial connection WiFi details and IP address were transferred to Sonoff. After restarting, Sonoff has already started up connected to my WiFi! A huge thank you to Grovkillen for making this program - it saves a lot of stress to beginning users like me.
"Force D-OUT"
Wow, thank you for the feedback!
- Methuselah
I have two Sonoff basics. The wifi chip is emprinted with "ESP8266EX" writing, but the only way I have gotten ESPEasy to work on it is to flash it with the 8285 image rather than the 8266 image.
N00b to the world of ESPEasy, but I've been programming since the days of punch cards and paper tape
Another struggler here.
Flashing my S20's didn't result in the device booting up correctly. Flashing the prebuilt bin files wouldn't work with the default flash tools, including the Espressif flasher...
After building the bin file myself using Arduino IDE, setting Board to Generic ESP8266 Module, Flash Mode to DOUT, and Flash Size to 1M (128 K Spiffs) I finally succeeded in flashing my Sonoff S20 devices (Chinese nock-offs, but fine quality altogether).
Thanks for all the tips I found here!
As with everyone else, I've spent stupid hours trying to flash my Sonoff S20 too.
It's a UK plug, the board is printed with S20_EU_V1.3 2017-2-16 1882.
The chip has ESP8266 printed on it.
I got it working with ESPEasy_v2.0.0-dev9_normal_8285.bin, which I flashed using MODEMCU Firmware Flasher. I changed to DOUT!
For whatever reason, the chip has 8266 printed on it, however only the 8285 firmware works! Trying to use the 8266 binary just results in a dead device.
Thank you to the others in this thread for highlighting the 8255 issue with the newer UK S20 devices.
I use the CP2102 moduls USB-TTL connecter and plug the four pins to the correct header points on the S20.
One thing I discovered is that (for me) using the S20's
– S20's with versions < v1.3 - I need to connect TX-RX and RX-TX
– S20's with versions v1.3+ – I need to connect TX-TX and RX-RX.
Users browsing this forum: No registered users and 57 guests
