After updating two of my ESP's from ESPEasy_v2.0.0-dev11 to ESPEasy_v2.0.0-dev12 with the latest commit b073379, I lost all settings and rules.
Was that to be expected? With the serial interface connected I saw during first reboot the following.
INIT : Booting version: (custom)
INIT : Warm boot #1
FS : Mounting...
FS : Mount successful, used 0 bytes of 2949250
RESET: Resetting factory defaults...
RESET: Warm boot, reset count: 1
RESET: formatting...
RESET: formatting done...
FILE : Saved config.dat
FILE : Saved security.dat
RESET: Succesful, rebooting. (you might need to press the reset button if you've justed flashed the firmware)
config and rules lost
Re: config and rules lost
I think you coudl have compiled 2.0.0-dev12 last commit yourself with wrong memory settings...BertB wrote: ↑18 Oct 2017, 18:56 After updating two of my ESP's from ESPEasy_v2.0.0-dev11 to ESPEasy_v2.0.0-dev12 with the latest commit b073379, I lost all settings and rules.
INIT : Warm boot #1
FS : Mounting...
ESPEasy shoudl be complied with 4M/1M SPIFF while Arduino IDE default is 4M/3M SPIFF if I remember correctly...
You are right.
How do you change flash settings if your useing the bin file
I also cannot save configs
Users browsing this forum: Ahrefs [Bot] and 96 guests
