ESPEasy and TSL2561
Posted: 27 Nov 2017, 17:12
Hi!
I just got my TSL2561 connected to a WEMOS D1 Mini working. Works great, much easier then when it was connected directly to my RPi with a very long cable.
I do notice a very large difference in the values produced with this setup and with the Python script I used before. This is a bit hairy, because my whole Domoticz is setup on these "old" values. I tried to replicate the output from the script in ESPEasy, but I'm missing a second value, that is used to calculate the outcome in the script (which I did't write myself BTW).
The script is:
I haven't found a way to replicate the esults.
Any ideas?
With kind regards,
Martijn
The script is:
# TSL2561
import smbus
import time
# Get I2C bus
bus = smbus.SMBus(1)
# TSL2561 address, 0x39(57)
# Select control register, 0x00(00) with command register, 0x80(128)
# 0x03(03) Power ON mode
bus.write_byte_data(0x39, 0x00 | 0x80, 0x03)
# Select timing register, 0x01(01) with command register, 0x80(128)
# 0x02(02) Nominal integration time = 402ms
bus.write_byte_data(0x39, 0x01 | 0x80, 0x02)
time.sleep(0.5)
# Read data back from 0x0C(12) with command register, 0x80(128), 2 bytes
# ch0 LSB, ch0 MSB
data = bus.read_i2c_block_data(0x39, 0x0C | 0x80, 2)
# Read data back from 0x0E(14) with command register, 0x80(128), 2 bytes
# ch1 LSB, ch1 MSB
data1 = bus.read_i2c_block_data(0x39, 0x0E | 0x80, 2)
# Convert the data
ch0 = data[1] * 256 + data[0]
ch1 = data1[1] * 256 + data1[0]
# Output data to screen
print "Full Spectrum(IR + Visible) :%d lux" %ch0
print "Infrared Value :%d lux" %ch1
print "Visible Value :%d lux" %(ch0 - ch1)
Any ideas?
With kind regards,
Martijn
