Page 1 of 4
ESP Easy Flasher
Posted: 29 Dec 2017, 14:25
by grovkillen
ESP Easy Flasher (
0.00.020)
A wrapper for the excellent command line tool ESPTOOL.exe and PowerShell. ESPTOOL.exe is used for flashing, PowerShell for serial (post flash) programming. All needed files are included in the EXE file, just download it and place it where you want it. It will extract needed file structure and missing files automatically. The idea behind the app is to make the flashing and setup of ESP Easy FW as stream lined as possible. It's still a very early stage but should hopefully be functional for most use-cases.
Flash features:
- Flash ESP8266 (+ESP8285) using embedded ESPTOOL.exe [0.4.12]
- Use maximum baud rate if wanted
- Use forced DOUT if wanted
Post flash features:
- Set Unit name, number, admin password, Wifi settings, IP
- Activate and upload rules
- Monitor serial port using plink.exe
Implemented
NOT implemented but on todo list
EXTRA INFO:
Agency FB is the font used within the app, if not present the app will kindly ask you to drag-and-drop the two font files found in the APP_DATA folder to the FONTS folder (automatically opened).
Admin rights are needed to be able to get COM port names (driver names).
BIN files need to be placed in the BIN folder (might change in the future but I plan to automatically download new releases from GitHub)
Log files for each flash will be placed in the Log folder.
Debug log is created by: save settings and open the ini file, change debug level 0 to 1, restart app and a bug log file will appear in the same place as the exe.
Debug logs are sent here, but please add information (email, name etc.) in the text file prior to upload!
ERROR handling if the flash tool is telling you that an error has occured, a standard test is to simply reset the unit (if the unit has a switch for this, use that one, else disconnect the cable) and then try again. Flashing over serial is not an exact science.
I plan add more features on a weekly basis. Thanks for all the feedback!
>>RELEASES ARE FOUND HERE<<
Re: ESP Easy Flasher
Posted: 29 Dec 2017, 16:52
by mrwee
Very nice! Good work. Will try it out
Posted: 29 Dec 2017, 17:05
by papperone
That looks so nice and useful!
Will give it a try once I am back from my seasonal holidays!!!
Posted: 29 Dec 2017, 18:51
by grovkillen
The rules are not implemented yet. Thanks for the thumbs up!
Posted: 29 Dec 2017, 19:30
by Shardan
Just downloaded.. will test as soon as possible.
Posted: 29 Dec 2017, 20:40
by AndrewJ
That looks fantastically useful, thank you!
AndrewJ
Posted: 29 Dec 2017, 21:31
by grovkillen
Thanks for the feedback, hopefully you will find it useful. In will add more info on the GitHub page in how to use it etc. But I wanted it out in the wild asap
Posted: 29 Dec 2017, 22:29
by budman1758
This looks great! Does it also work on ESP32?
Posted: 29 Dec 2017, 23:20
by grovkillen
budman1758 wrote: ↑29 Dec 2017, 22:29
No, ESP32 is not supported.
Posted: 31 Dec 2017, 11:03
by jeti
looks awesome!
just tested it on a wemos d1 mini (system is Windws 10):
- COM port: Dropdown took a while, but works, found the correct COM -> i just double checked did not find the correct COM port
- Firmware: works fine if bin is in "BIN" folder "Browse" only opens file explorer wich no way to choose the wanted bin
- Fields for Details are working but format is off
- "flash ESP Easy" did "start" but not the flashing process
- Log Folder is empty
do you need anymore Information?
Thanks for your awesome work!
Posted: 31 Dec 2017, 12:04
by grovkillen
jeti wrote: ↑31 Dec 2017, 11:03
looks awesome!
- COM port:
Thanks for feedback! I will try to update later today (especially include the font and log failed attempts of flash).
Posted: 31 Dec 2017, 20:39
by grovkillen
looks awesome!
- COM port:
I have now included the missing font in the latest release (0.00.007).
Posted: 02 Jan 2018, 13:59
by grovkillen
Ok, I have now released a new version (0.00.008) which allows you to upload rules (if you have activated "post flash actions"). I also made the log much more extensive and tried to find possible errors. It will now warn more if the flash didn't complete as suspected.
ENJOY!
Posted: 02 Jan 2018, 17:19
by mrwee
Kanon bra - tack!
Posted: 03 Jan 2018, 17:12
by joemoer
grovkillen wrote: ↑31 Dec 2017, 20:39
looks awesome!
- COM port:
Just tested your 0.00.009 version. I am getting the same problem as "jeti".
The program indicates that it has started flashing, but "esptool" is not opening and nothing is being written into the log folder. Device not programmed.
This on two windows 10 (64 bit) PC's.
Posted: 03 Jan 2018, 17:21
by grovkillen
Sorry to hear that. In guess (?) it's the ESPTOOL issue (#60) you are experiencing....
https://github.com/igrr/esptool-ck/issues/60
I will try to capture this error (in worst care a time out trigger). So at least the log will output this... Thanks for the feedback!
I wish I had 64-bit Windows 10 at home to test. Will try to fix tomorrow.
Posted: 03 Jan 2018, 19:29
by grovkillen
I realized that I do have a 64-bit Win10 machine at home. I will try to see if this is an issue for me as well...
Posted: 03 Jan 2018, 19:50
by grovkillen
I have now tested and I cannot reproduce the issue. But I do get problem if the COM1 is not occupied by any driver. I changed one of my higher COM port drivers to point to COM1 and it started working as intended. Is this an issue that could be what you're experiencing? See how I changed the settings in the picture below:
control panel --- device manager --- settings for com port --- port settings --- advanced --- com port number
Posted: 03 Jan 2018, 19:58
by budman1758
I'm having a similar problem. Windows 10 64 bit laptop. Does not list the COM ports correctly or at all. When the active ports box is checked I get no ports listed. When unchecked it shows some (not all) and says (off line) after the name.
I will try the flasher on my server later. Its a Windows 7 machine. 64 bit.
Posted: 03 Jan 2018, 20:10
by grovkillen
budman1758 wrote: ↑03 Jan 2018, 19:58
Could you please check and see if COM1 is occupied?
Posted: 03 Jan 2018, 20:37
by budman1758
I just tried to move the com port to com1 like your example and it now shows a USB/Serial device. Tried to flash a module but nothing happens. ESP Tool window does not come up. Module not flashed.
Posted: 03 Jan 2018, 20:55
by grovkillen
budman1758 wrote: ↑03 Jan 2018, 20:37
The ESPTOOL command window is hidden and should not pop up (might need to make a device debug setting which show everything)... I need to fix the issue with unassigned com1. Is the found com port the correct one of you check in the device manager?
Posted: 03 Jan 2018, 22:01
by budman1758
Almost every time I insert the USB flasher it comes up as com4 or com5. Using your example I "forced" it to com1. It now shows as a USB Serial device. But it does not flash the module. Zero activity shows on the device. It has two leds for rx and tx. Click the flash button in the app and info window says "Start flashing on com1" but nothing is happening.
Posted: 03 Jan 2018, 22:10
by grovkillen
budman1758 wrote: ↑03 Jan 2018, 22:01
Super weird. What does the log file say? (Located in the log folder)
Posted: 03 Jan 2018, 22:46
by budman1758
Log folder is empty.
Posted: 03 Jan 2018, 22:54
by grovkillen
Now that tells me that something else is causing the problem!
Can you tell me the search way / path that you have your exe in?
Posted: 03 Jan 2018, 23:10
by budman1758
C:\Users\Budman\Documents\Arduino Docs\ESPeasy Stuff\Flash Utilities\ESP_Easy_Flasher-master
Made a copy and put it the root of the C drive and getting same behaviour.
Posted: 03 Jan 2018, 23:37
budman1758 wrote: ↑03 Jan 2018, 23:10
Perhaps also try in C:\Users\Budman\Documents\
The root of the C drive may be a permission issue to write there and the other one has a space in the path, which is generally very often an issue with software.
So just to exclude both, try to save in your own documents folder.
Of try to run it as administrator.
Posted: 04 Jan 2018, 00:47
by budman1758
TD-er wrote: ↑03 Jan 2018, 23:37
Tried it in Documents root. Same behaviour.
I always run it as Admin.
Posted: 04 Jan 2018, 01:25
by budman1758
I'm also having the same problems on my Win 7 64 bit machine. Is this a "64 bit" problem?
As a side note. After hitting the x to close the program it is still running in Task Manager. Have to kill the process. This is on Win 7 and NOT on my Win 10 machine. Strangeness abounds......
Posted: 04 Jan 2018, 05:55
by grovkillen
budman1758 wrote: ↑04 Jan 2018, 01:25
I will test it further today. Hopefully I can trigger the behavior on another computer. Sir thank you for your time and help!
Posted: 04 Jan 2018, 07:04
by budman1758
grovkillen wrote: ↑04 Jan 2018, 05:55
Ain't no thing Bro. Anyway I can help, I'm there.
I just wish I could help on the programming side. There, me be pretty much useless....
Posted: 04 Jan 2018, 21:46
by dennist
Same here. i do not see any com ports.
Posted: 04 Jan 2018, 22:13
by grovkillen
I'm really sorry to hear this. I will try to make a version with more debug output. Thank you all for the feedback. I will make this work!
Posted: 05 Jan 2018, 11:03
by grovkillen
budman1758 wrote: ↑04 Jan 2018, 07:04
I have now released a new version (not in released folder) but in the
main code page. Please download it and test. You need to save a default settings file and change the debug level from 0 to 1. If you don't get that far you can download it
from me here (place it in the settings folder).
You can upload the DEBUG FILE here:
https://dbinbox.com/harkrank
Posted: 05 Jan 2018, 18:09
by grovkillen
I have started to re-write the com scanner module, I think it will work more generically. Stay tuned.
Posted: 06 Jan 2018, 14:38
by grovkillen
I have now commited 0.00.014 with the new com scanner module. I hope this will fix a lot of the issues reported here
ONLY usb com ports are being scanned with this new com scanner, I think no one really uses "true" com ports?
Posted: 07 Jan 2018, 00:47
by Shardan
Just a rough idea:
If i remember right the Esptool is able to detect the flash type/size and it is able to erase the flash.
Would be a nice expansion to your tool if I'm right
Posted: 07 Jan 2018, 07:27
by grovkillen
Shardan wrote: ↑07 Jan 2018, 00:47
Just a rough idea:
I might add that as well, thanks for the idea. Erase flash is actually something I'd use from time to time. Thanks!
Posted: 07 Jan 2018, 10:35
Just a rough idea:
Yesterday I added some info (in a
pull request) to display all information of the flash possible.
Adding a "erase all flash" from within ESPeasy is not that hard. (just to erase all settings, not the firmware itself)
I already saw the instructions for it, when browsing the code to determine the flash size, speed, etc.
It now prints in the sysinfo screen:
ESP Chip ID: 1649343
ESP Chip Freq: 80 MHz
Flash Chip ID: Vendor: 0xE0 Device: 0x4016
Flash Chip Real Size: 4096 kB
Flash IDE Size: 4096 kB
Flash IDE speed: 40 MHz
Flash IDE mode: DIO
I still have to look into determine the ESP chip, since the current ID shown is just the last halve of the MAC address, when using an ESP8266.
Posted: 08 Jan 2018, 20:05
by grovkillen
Please give me feedback if the new com scanner is not working!
Posted: 08 Jan 2018, 22:04
by budman1758
OK. Here is whats happening on my Win 10 64bit system. I have 2 USB to serial devices. 1 is a CH340 1 dollar China unit. The other is a genuine FTDI chip unit I got from Adafruit.
No matter what com port I either manually assign or let windows assign the flash program NEVER identifies the FTDI device.
The flash program correctly identifies the CH340 EVERY time with the correct com port.
NEITHER of them work however. I go through the motions to flash a module and the program acts like all is well but nothing happens. Zero activity out of the serial device. Program window says "flashing.. might take a few" but nothing is working. When I press flash button it greys out and stays that way until I exit the program.
Maybe of interest... When I exit the program BEFORE attempting to flash it exits cleanly. If I press flash button and then try to exit the program it ACTS like it exits cleanly but in Windows task manager it is still running. Couple of screenshots of that are in your upload folder.
Always run as admin. There are 2 hidden windows running in the background. Might be helpful if those were visible during testing.
I uploaded some screenshots and log files to your upload location. Log file does not look very helpful. (to me anyway.
Hope this is helpful. Sorry it took a while to get back on this. Let me know what else I can do to help.
Posted: 08 Jan 2018, 22:38
by grovkillen
Thank you very much. The debug should show the command windows, I will make that in the next version. The debug log is supposed to be filled with approx 10000+ of code of working properly so we have some issue there it seems. The screenshots of the device manager showing com5, is that the FTDI programmer? Shouldn't the driver state something more specific than "serial..."?
I will upload a new version tomorrow, much appreciated that you take your time. I will get to the bottom of this!
Posted: 08 Jan 2018, 23:19
by budman1758
grovkillen wrote: ↑08 Jan 2018, 22:38
Yes, it is. It does show more detail if you go into the properties a bit deeper. I would have thought the same thing. Kinda generic for a $17 dollar "genuine FTDI".
Posted: 09 Jan 2018, 11:26
by grovkillen
budman1758 wrote: ↑08 Jan 2018, 23:19
Please try latest release ...
https://github.com/Grovkillen/ESP_Easy_ ... g/0.00.016
Posted: 09 Jan 2018, 20:18
by budman1758
OK. Still not finding my FTDI serial port. Correctly finds the CH340 on correct com port. Lots of windows flicker in background.
When the app window appears it is still scanning for comports.
When done a command window opens and at the top is says cannot find the specified path.
The command line is focused in the APP_DATA folder of the flash app.
Even when trying with my CH340 device nothing happens.
I uploaded my debug file to your dropbox. It's quite a bit more informative.
Hope this helps.
Posted: 09 Jan 2018, 20:30
by grovkillen
budman1758 wrote: ↑09 Jan 2018, 20:18
Hope this helps.
Great! I have come to the conclusion that since I now only scan for USB TTL ports the FTDI might not consider itself as such?
(COM4) Silicon Labs CP210x USB to UART Bridge
(COM6) USB-SERIAL CH340
(COM7) USB-SERIAL CH340
(COM8) USB-SERIAL CH340
Those are found with USB but I bet the FTDI specifies itself as good ol serial..? If you go to the device manager and look in the code described in the picture below. What does that say for the FTDI programmer?
Also the date format is messing with my variables since the US "\" between the dates are interpreted as path's (in my code). I will hard code ISO date
Lastly, the APP_DATA folder, what files is inside of it?
(Flickering is me pinging com ports, I will continue ping 10 com ports above the last one scraped from the registry...)
Posted: 09 Jan 2018, 21:06
by budman1758
My device is not the one in your screenshot. It is COM5 also.
The APP_DATA folder contains:
esptool.exe
TimeStamp.vbs
Screenshot of what I believe is similar to yours.
I have hidden devices showing. Those are the ones that are greyed out.
Hope this helps.
- Capture.JPG (95.19 KiB) Viewed 126765 times
Posted: 09 Jan 2018, 21:35
by grovkillen
Posted: 09 Jan 2018, 22:05
by budman1758
