ESP Easy Webdumper
Re: ESP Easy Webdumper
thank you for the answer
however, he is in the same folder
sorry for my English ! i use google translat.
Do you mind testing current version 0.00.012 (found here): https://github.com/Grovkillen/ESP_Easy_ ... dumper.exe
Yessssssssss 0.00.012 works
It works. Still thank you.
I'm going to take advantage of the French jeedom
Great news
Thanks for the feedback.
would it be possible to decrease the size of the files.
with webdumper .... 2.41M !
with capture tool .... 41K, better for forums.
thank
thank
I'm gonna look into it. I make uncompressed pictures, will fix it so they are compressed by default.
Hi Grovkillen,
An idea, the total time taken !
This could be used as a measure of web-server performance to measure differences in firmwares
Cheers
Cheers
Sure, that can be added.
ESP Easy Webdumper & Performance Tool
Excellent, I was awake for over 36 hours configuring my 'test environment' - I have an older firmware which has not yet failed,
so I have a base line, a few hours 'power sleep' and I am back.
Only 2 firmware versions higher & I see 'bad behaviour' - very pleased, but so much more to do before I track down the exact cause.
If those performance results could go into a file with the firmware version & time taken, that would save 'manual' effort keeping track.
Time to dump the current failing firmware & OTA update the next.
0.01.002 is now available. Fixed problem with not being able to fetch the unit name an number.
https://github.com/Grovkillen/ESP_Easy_ ... r/releases
Users browsing this forum: Ahrefs [Bot] and 111 guests
