Portable syslog server for test/bug check
I use this setup for getting the logging done in a easy way (normally I use serial debugging but once a unit is online and placed somewhere it's not easy to get to it physically).
Just download the portable application and unzip it somewhere on your Windows machine: https://github.com/peacepenguin/tftpd64/releases I use the tftpd64 portable edition (4.60).
On the ESP Easy you go to advanced, enter the IP of your machine where you run the tftpd64 application. Change syslog level to 4 and then you just go to the correct tab (Syslog server) and wait for incoming messages.
Remember to remove the settings (IP="blank" and loglevel=0) once you're done.
- SysLogServer.png (61.53 KiB) Viewed 11332 times
- budman1758
Re: Portable syslog server for test/bug check
+1
Now we need a "enable" checkbox for the syslog function.
Let's make an issue budman!
- budman1758
Wau!! Thank you.
New hosted site found here: https://github.com/peacepenguin/tftpd64/releases
Users browsing this forum: No registered users and 102 guests
