I'm trying to build a rule where my nodemcu would send me a Pushover notification on an EVENT.
I tried the following rule:
On start_pushover do
SendToHTTP api.pushover.net,443,/1/messages.json?token=XXXX?user=XXXX?device=iphone?title=test?message=Test
XXXXX are changed in my rule with my own token and user
when I send the following command through a web browser: http://"MYESPIP"/control?cmd=event,start_pushover I see in the esp log file that the command was received and that the rule was run:
2733015 : EVENT: start_pushover
2733038 : ACT : SendToHTTP api.pushover.net,443,/1/messages.json?token=XXXX?user=XXXX
But the pushover message was never sent to my iphone.
I know that the api token and user used is functionnal since I can receive message when I manually used these info through another app.
Has anyone been able to get this to work ?
SendToHTTP and Pushover
Re: SendToHTTP and Pushover
Pushover requires httpS which is not what ESP Easy is sending. It will not work since implementing the secure layer is probably way more than what the ESP8266 can handle.
I see ...
I'm wondering why https could not be supported in easyesp, before using espeasy I was using the arduino IDE and builded few ino files including MQTT, Pushover, Wifi and it only used 25% of the resources ?
Well, specific code for one single function is one side, multipurpose FW like ESP Easy is another side. But please see what you can do and push it to the playground
We are currently on Arduino ESP8266 version 2.3.0
Version 2.4.0 and newer do have (better/more/stable) support for those S'es in various communications. (HTTPS/SSL/TLS)
And still with the 2.4.0 tests I ran, I had a lot of crashes.
