RSSI system variable
Hello All,
Recently just found ESPeasy and have it working sending data to my HA PC. I wanted to also send the RSSI from the ESPeasy to the HA PC. I managed to do this every minute with the rules section however this has highlighted an issue. My HA system does not respond with negative values and of course all the RSSI values are negative! Is there anyway I can perform any math on the variable or make it positive in value before I send it. I am very new to ESPeasy ie yesterday but I have searched the docs etc but I cant seem to find a way of doing this.
Thanks in advance,
regards
Ian
Thanks in advance,
regards
Ian
Re: RSSI system variable
Publish,TOPIC,[%RSSI%/-1]
BUT:
You can also do it with the plugin "Genetic - System Info". Use the formula %value%/-1 and set the delay to 60 seconds.
Many thanks for the suggestion. I should have mentioned I am using http as the sending method. this is the rule below:
On Rules#Timer=1 do //When Timer1 expires, do
SendToHTTP 192.168.2.203,80,/JSON?request=controldevicebyvalue&ref=92&value=%rssi%/-1
timerSet,1,60
As you see I did try to add the divide by -1 on the end of SendToHTTP but this simply sent out the following:
Request URI Query: request=controldevicebyvalue&ref=92&value=-82/-1
as grabbed by Wireshark running on the HA PC. You also mentioned "Genetic - System Info" as a plugin. I have not got as far as plugins so I'll do some more research and see what I can find..
Thank you
Ian
timerSet,1,60
Thank you
Ian
A suggestion (but it's only that, as I've never played with negative numbers in ESPeasy!) - you might need to use a dummy task, and do the division (or multiplication) by -1 in a rule, putting the result into the dummy. Then a rule to send the (now positive) value out.
Any plugin has some very basic formula option to do something with the recorded value.AndrewJ wrote: ↑31 Mar 2018, 21:59 A suggestion (but it's only that, as I've never played with negative numbers in ESPeasy!) - you might need to use a dummy task, and do the division (or multiplication) by -1 in a rule, putting the result into the dummy. Then a rule to send the (now positive) value out.
Just to give an idea on the interpretation of the RSSI values.
For the Domoticz controllers, the RSSI value is converted to a range of 0...10.
RSSI values > -50 -> 10
RSSI values < -98 -> 0
For the rest: ((rssi + 97) /5 ) +1
Excellent tip, thanks TD-er
Thanks all for the help,
As I mentioned very new to ESPeasy so please bear with me in case I am missing something straight forward.
So the rule is as follows:
timerSet,1,60
I am fairly certain I can not add anything on the SendToHTTP line as this simply gets sent out as the HTTP message as is and doesn't actually perform any math etc.
So normally I would use a variable do the math then send out the new variable. No variables in ESPEasy but dummy devices as a fix. Looking at dummydevices I have found this post
viewtopic.php?t=1808
I understand how to set the value I think as follows:
TaskValueSet 10,1,%rssi% / -1
So this would use dummy device 10 var 1 to hold the new rssi value. However on the ESPeasy webpage I dont have the option to select a "Dummy" as a device which I have seen in a screen shot elsewhere and also I'm not sure how to send out the new dummy value. I am sure I am missing something but cant find the answer. I need to change this line to include the new value which would normally be something like this
SendToHTTP 192.168.2.203,80,/JSON?request=controldevicebyvalue&ref=92&value=%TaskValueSet10,1%
Which I know is incorrect but I cant see were any other reference is made to the name of 10,1 to use it to assign, unless it is to do with the dummy device which I dont have and could explain why i am struggling to do this.
once again thanks for the help.
regards
Ian
timerSet,1,60
regards
Ian
Math need to be closed with brackets:
[%rss%/-1]
This is proving to be more difficult than I had expected. I changed the rule but didnt get any value so as a test I just added the brackets like this
SendToHTTP 192.168.2.203,80,/JSON?request=controldevicebyvalue&ref=92&value=[%rssi%]
timerSet,1,60
Now I dont get any value sent at all the http request is terminated after the "value=" and nothing more.
I have searched for any example of math being done on a SendToHTTP command but so far have not found anything.
Thank you
Ian
timerSet,1,60
Thank you
Ian
You could dump the result to a dummy device before publishing it.
Many thanks to everyone, I now have this working.
The rule is as follows:
TaskValueSet 10,1,%rssi%/-1
SendToHTTP 192.168.2.203,80,/JSON?request=controldevicebyvalue&ref=92&value=[Dummy#Dummy_1]
timerSet,1,60
With the TaskValueSet command dont use brackets for math. As regards the dummy device I could not find this but I should have looked harder. The devices are listed in alphabetical order and I couldnt see "dummy" but then found it listed as generic - dummy. Everything then made sense and it is all working fine. I have created some wifi icons and mapped them to the signal strength so hopefully this part is now sorted.
Thanks again
regards
Ian
timerSet,1,60
Thanks again
regards
Ian
Users browsing this forum: Ahrefs [Bot], Google [Bot] and 35 guests
