ESP Wifi Gone after saving settings
I successfully flashed esp easy to my touch wall switch.
Also I was able to setup my wifi settings, and open the http://EASYESPIP/ web control
I can already issue command manually through http://EASYESPIP/control?cmd=GPIO,13,1 and so on
Trying to enable device, (referring from this guide - https://www.letscontrolit.com/wiki/inde ... ch_002.PNG)
When I hit submit, it just hangs and then i cannot open http://EASYESPIP/ anymore.
Tried flashing it again, and it was successful, however ESP_WIFI is not showing this time(same firmware i used but it was working before i did not enable device or hit the submit button)
I am wondering why the wifi is not functioning after I submit settings in the devices.
I was thinking my touch switch has been broken, so I tried again with a new touch wall switch.
Everything works fine again, but after submitting settings in the "devices" menu, it does not work again.
I tested 2 touch wall switch and everything works fine at first.
This is the product i used,
https://www.aliexpress.com/item/New-Ewe ... 78982.html
and its showing PSF-B85.
I hope someone can help.
Thanks a lot!
Thanks a lot!
Re: ESP Wifi Gone after saving settings
If you're on Windows you could try my Flasher and use the serial monitor to see what the unit is doing.
Bit more info plz, hardware by ? ESp chip 8266? Firmware version ?
Ta
Ta
will try now, thank you!grovkillen wrote: ↑02 Apr 2018, 10:25 If you're on Windows you could try my Flasher and use the serial monitor to see what the unit is doing.
https://www.itead.cc/wiki/PSF-B85
Yep 8285...
ESP_Easy_mega-20180402_normal_ESP8285_1024.bin listed as 608K in size.
Ok watching from side lines
Yep 8285...
hello,grovkillen wrote: ↑02 Apr 2018, 10:25 If you're on Windows you could try my Flasher and use the serial monitor to see what the unit is doing.
here is the log file
######2018-04-02######
#######0.00.025#######
######FLASH INFO######
BIN file: ESP_Easy_mega-20180402_normal_ESP8285_1024.bin
COM port: (COM3) Silicon Labs CP210x USB to UART Bridge
Baud rate: 115200
######POST FLASH######
Unit name: test
Unit number: 1
Admin password: yyy
WiFi SSID 1: xxx
WiFi password 1: yyy
WiFi SSID 2:
WiFi password 2:
IP: 192.168.0.210
######FLASH LOG######
[esptool.exe -vv -cd nodemcu -cb 115200 -cp COM3 -ca 0x00000 -cf "C:\Users\Daddy\Downloads\BIN\ESP_Easy_mega-20180402_normal_ESP8285_1024.bin"]
[4/2/2018 4:45:06 PM] esptool v0.4.12 - (c) 2014 Ch. Klippel <ck@atelier-klippel.de>
[4/2/2018 4:45:06 PM] setting board to nodemcu
[4/2/2018 4:45:06 PM] setting baudrate from 115200 to 115200
[4/2/2018 4:45:06 PM] setting port from to COM3
[4/2/2018 4:45:06 PM] setting address from 0x00000000 to 0x00000000
[4/2/2018 4:45:06 PM] espcomm_upload_file
[4/2/2018 4:45:06 PM] espcomm_upload_mem
[4/2/2018 4:45:06 PM] setting serial port timeouts to 1000 ms
[4/2/2018 4:45:06 PM] opening bootloader
[4/2/2018 4:45:06 PM] resetting board
[4/2/2018 4:45:06 PM] trying to connect
[4/2/2018 4:45:06 PM] flush start
[4/2/2018 4:45:06 PM] setting serial port timeouts to 1 ms
[4/2/2018 4:45:06 PM] flush complete
[4/2/2018 4:45:06 PM] espcomm_send_command: sending command header
[4/2/2018 4:45:06 PM] espcomm_send_command: sending command payload
[4/2/2018 4:45:06 PM] read 0, requested 1
[4/2/2018 4:45:06 PM] espcomm_send_command: receiving 2 bytes of data
[4/2/2018 4:45:06 PM] Uploading 621632 bytes from C:\Users\Daddy\Downloads\BIN\ESP_Easy_mega-20180402_normal_ESP8285_1024.bin to flash at 0x00000000
[4/2/2018 4:45:06 PM] erasing flash
[4/2/2018 4:45:06 PM] size: 097c40 address: 000000
[4/2/2018 4:45:06 PM] first_sector_index: 0
[4/2/2018 4:45:06 PM] total_sector_count: 152
[4/2/2018 4:45:06 PM] head_sector_count: 16
[4/2/2018 4:45:06 PM] adjusted_sector_count: 136
[4/2/2018 4:45:06 PM] erase_size: 088000
[4/2/2018 4:45:06 PM] setting serial port timeouts to 15000 ms
[4/2/2018 4:45:06 PM] writing flash
[4/2/2018 4:45:14 PM] ................................................................................ [ 13% ]
[4/2/2018 4:45:22 PM] ................................................................................ [ 26% ]
[4/2/2018 4:45:30 PM] ................................................................................ [ 39% ]
[4/2/2018 4:45:38 PM] ................................................................................ [ 52% ]
[4/2/2018 4:45:46 PM] ................................................................................ [ 65% ]
[4/2/2018 4:45:54 PM] ................................................................................ [ 78% ]
[4/2/2018 4:46:02 PM] ................................................................................ [ 92% ]
[4/2/2018 4:46:07 PM] ................................................ [ 100% ]
[4/2/2018 4:46:07 PM] starting app without reboot
[4/2/2018 4:46:07 PM] espcomm_send_command: sending command header
[4/2/2018 4:46:07 PM] espcomm_send_command: sending command payload
[4/2/2018 4:46:07 PM] espcomm_send_command: receiving 2 bytes of data
[4/2/2018 4:46:07 PM] closing bootloader
[4/2/2018 4:46:07 PM] flush start
[4/2/2018 4:46:07 PM] setting serial port timeouts to 1 ms
[4/2/2018 4:46:07 PM] setting serial port timeouts to 1000 ms
[4/2/2018 4:46:07 PM] flush complete
[2018-04-02 16:46:07] DONE!
[2018-04-02 16:46:07] Sending SERIAL: "Name test"
[2018-04-02 16:46:09] Sending SERIAL: "Unit 1"
[2018-04-02 16:46:11] Sending SERIAL: "Password yyy"
[2018-04-02 16:46:13] Sending SERIAL: "WifiSSID xxx"
[2018-04-02 16:46:14] Sending SERIAL: "WifiKey yyy"
[2018-04-02 16:46:16] Sending SERIAL: "IP 192.168.0.210"
[2018-04-02 16:46:18] Sending SERIAL: "Save"
[2018-04-02 16:46:20] Sending SERIAL: "WifiConnect"
[2018-04-02 16:46:20] Serial programming done.
[2018-04-02 16:46:33] ERROR: Unit do not have an IP address.
[2018-04-02 16:46:33] JOB COMPLETED, over and out!
it managed to flash, but i still cannot connect to its wifi nor open http://192.168.0.210/
and serial monitor result:
wdt reset
tail 8
chksum 0x2d
csum 0x2d
v09826c6d
~ld
¬U
INIT : Booting version: mega-20180402
RTC : Checksum error on reading RTC user var
INIT : Warm boot #28
FS : Mounting...
FS : Mount successful, used 76053 bytes of 113201
CRC : program checksum ...OK
CRC : Settings CRC ...OK
CRC : SecuritySettings CRC ...OK
INIT : Free RAM:20296
INIT : I2C
INIT : SPI not enabled
keeps on looping like that
wdt reset
tail 8
chksum 0x2d
csum 0x2d
v09826c6d
~ld
¬U
FS : Mounting...
INIT : I2C
Hmm, did you use the pause function to reboot the device right after the flash? I didn't seem like it from the flash log. Might help?
tried the "pause after flash"grovkillen wrote: ↑02 Apr 2018, 10:56 Hmm, did you use the pause function to reboot the device right after the flash? I didn't seem like it from the flash log. Might help?
and here is the result
[2018-04-02 17:05:41] Waiting for user input (reset the unit).
[2018-04-02 17:06:00] Proceeding...
[2018-04-02 17:06:00] Sending SERIAL: "Name test"
[2018-04-02 17:06:02] Sending SERIAL: "Unit 1"
[2018-04-02 17:06:04] Sending SERIAL: "Password yyy"
[2018-04-02 17:06:05] Sending SERIAL: "WifiSSID xxx"
[2018-04-02 17:06:07] Sending SERIAL: "WifiKey yyy"
[2018-04-02 17:06:09] Sending SERIAL: "IP 192.168.0.211"
[2018-04-02 17:06:11] Sending SERIAL: "Save"
[2018-04-02 17:06:13] Sending SERIAL: "WifiConnect"
[2018-04-02 17:06:13] Serial programming done.
[2018-04-02 17:06:26] ERROR: Unit do not have an IP address.
[2018-04-02 17:06:26] JOB COMPLETED, over and out!
Could you try -just as a test- the PUYA firmware version?
Do you remove the gnd from gpio 0?
so i figured it out.
i just followed this guide
http://www.pratikpanda.com/completely-f ... sh-memory/
and everything is back to normal.
thanks for the ESP flash tool by the way, it's so useful!
Users browsing this forum: No registered users and 91 guests
