Have the same problem. During the flash by the GUI the s20 was blinking and at a specific momentTungstenE2 wrote: ↑04 Apr 2018, 19:35 I have now tested with 'ESP Easy Flasher'.
Tried several .bin including ESPEasy_R147_1024 and with or without setting Wifi.
In all cases flashing is done, but Wifi is not working.
without setting: no ESP wifi is started
with setting: error message 'Unit do not have IP'
Any other idea? Please help!
This is really frustrating. How come that updating via OTA is failing and the device is dead?
there was a major flash of the leds en the s20 was dead.
Connecting the programmer shows no com port and several leds on the programmer.
After a short of the rx/tx pins in connection with the programmer powered via usb,
The programmer showed up in the com ports.
Then loaded the blank.bin and after that the easysp that goes well. But no activity on the
S20 after that. No Wifi No leds. It seams that there is no power on it. Is it possible to
measure it and so yes where/what?
Is it possible that the s20 goes defective when programming FW over the GUI of the easysp?
Is the s20 realy dead or can I make it alive again?????? And how do I use the tool to clear
the s20 total to load a new FW.
Thanks in advance for all the help.
