Question about Status
In the log file I see the status of my switch device changes ever second, is this normal?
- switch state.jpg (113.07 KiB) Viewed 4421 times
Re: Question about Status
No not normal. Can you measure the GPIO and see if it's not quite high enough voltage wise making it jump like that?
Sorry but I don't have necessary tools to measure GPIO. I think with the previous firmware I did not have had this problem.
Currently I'm on 20180306
I'm not certain, but the use of "Switch" for both the task and the value may be causing problems.
You could try changing them to see if it helps.
AndrewJ you are a genius, it works thanks
Glad to be of help!
Good spotted!
Users browsing this forum: Google [Bot] and 99 guests
