How tu acivate / use P54 - DMX plugin
kr0815
#1 Post by kr0815 » 08 Apr 2018, 23:21
I want to try out the DMX plugin, but how to activate it?
It´s that one:
https://github.com/letscontrolit/ESPEas ... DMX512.ino
As i understand, it´s a regular plugin already included in the main branch?
Is there a way to check which plugins are available in a flashed version?
I could see installed "input" devices in Device section, but how to see / activate available "output" devices?
Klaus
sentinel
Re: How tu acivate / use P54 - DMX plugin
#2 Post by sentinel » 18 Apr 2018, 20:47
The official list of plugins is here.
The one you are interested in is under test, so you need to flash your module with a test binary.
You can also see output devices in the Device section, for example LCD.
Smotek7
#3 Post by Smotek7 » 25 Jan 2022, 17:32
I'm testing DMX,
It works for me on the Wemos D1 board.
It doesn't work for me on the WT32 board.
But if on WT32, for example, send a PWM command
http: // IP / control? cmd = PWM, 2.50
so on GPIO I have a PWM signal.
But DMX does not generate.
I use
ESP_Easy_mega_20211224_test_A_ESP8266_4M1M.bin
a
ESP_Easy_mega_20211224_test_A_ESP32_4M316k.bin
Smotek7
#4 Post by Smotek7 » 25 Jan 2022, 19:57
Also tested on ESP32 WROOM
it also doesn't work.
When I put the Oscilloscope there, I see some short signal about 10Hz.
Wemos D1 signal
ESP32
Users browsing this forum: No registered users and 94 guests
