HW: nodeMCU 1.0 v3 (ESP-12E Module), 80MHz, 115200, 4M (3M SPIFFS), COM33
- https://www.aliexpress.com/item/-/32820380705.html
- powered by microUSB connector, good power supply
ArduinoIDE 1.8.5, files placed to Portable folder, libraries updated
- over IDE I have no problems to reflash ESP any time
mega-20180403 and edited ESPEasy-Globals.h
- ssid & pass
- IP for controller (OpenHAB MQTT)
- DEFAULT_USE_RULES true
- DEFAULT_MQTT_RETAIN true
- #define PLUGIN_BUILD_DEV
So far so good, everthing is working wo. any problems. ESP gets IP from DHCP (reserved for MAC), so I'm able to configure board via browser.
Log from serial - flashing over IDE:
INIT : Booting version: (custom)
INIT : Cold Boot
FS : Mounting...
FS : Mount successful, used 0 bytes of 2949250
RESET: Resetting factory defaults...
RESET: Warm boot, reset count: 0
RESET: formatting...
RESET: formatting done...
FILE : Saved config.dat
FILE : Saved security.dat
RESET: Succesful, rebooting. (you might need to press the reset button if you've justed flashed the firmware)
ets Jan 8 2013,rst cause:2, boot mode:(1,6)
ets Jan 8 2013,rst cause:4, boot mode:(1,6)
wdt reset
rl
INIT : Warm boot #1
FS : Mounting...
FS : Mount successful, used 75802 bytes of 2949250
CRC : No program memory checksum found. Check output of crc2.py
CRC : Settings CRC ...OK
CRC : SecuritySettings CRC ...OK
INIT : Free RAM:16112
INIT : I2C
INIT : SPI not enabled
EVENT: System#Wake
WIFI : AP Mode disabled
WIFI : AP Mode ssid will be ESP_Easy-0 with address 192.168.4.1
WIFI : Connecting wlan24 attempt #0
OTA : Arduino OTA enabled on port 8266
EVENT: System#Boot
WD : Uptime 0 ConnectFailures 0 FreeMem 12744
WIFI : Connected! AP: wlan24 (84:16:F9:BB:BB:6D) Ch: 1 Duration: 3991 ms
EVENT: WiFi#ChangedAccesspoint
WIFI : DHCP IP: 192.168.0.175 (ESP-Easy-0) GW: 192.168.0.1 SN: 255.255.255.0 duration: 3657 ms
EVENT: WiFi#Connected
Current Time Zone: DST time start: 2018-03-25 02:00:00 offset: 60 minSTD time start: 2018-10-28 03:00:00 offset: 0 min
EVENT: Time#Initialized
EVENT: Clock#Time=Wed,21:57
EVENT: Clock#Time=Wed,21:58
WD : Uptime 1 ConnectFailures 0 FreeMem 12120
Here is serial otput:
Update: ESP_Easy_mega-20180409_dev_ESP8266_4096.bin
sleep disable
.....................................................................................................................................................................ERROR[0]: No Error
.ERROR[0]: No Error
.ERROR[0]: No Error
...........................................................................................................................................................................Update Success: 691776
Rebooting...
ets Jan 8 2013,rst cause:2, boot mode:(3,6)
tail 8
chksum 0x2d
csum 0x2d
v09826c6d
@cp:0
ld
⸮U
INIT : Booting version: mega-20180409
INIT : Cold Boot
FS : Mounting...
FS : Mount successful, used 0 bytes of 957314
tail 8
chksum 0x2d
csum 0x2d
v09826c6d
~ld
⸮U
INIT : Warm boot #1
FS : Mounting...
FS : Mount successful, used 75802 bytes of 957314
CRC : program checksum ...FAIL
CRC : Settings CRC ...FAIL
CRC : binary has changed since last save of Settings
INIT : Free RAM:17416
INIT : I2C
Exception (0):
epc1=0x402522ee epc2=0x00000000 epc3=0x00000000 excvaddr=0x00000000 depc=0x00000000
ctx: cont
sp: 3fff55e0 end: 3fff58c0 offset: 01a0
>>>stack>>>
3fff5780: 0000001e 00000012 3fff5810 4020c43d
3fff5790: 3ffe8ae4 00000000 3fff5810 4020c48e
3fff57a0: 3ffe8ae4 00000001 3ffe8ffd 40216164
3fff57b0: 00000000 00000015 3fff57d0 0000001b
3fff57c0: 3fff1ae0 00000006 3fff57d0 40221a30 <
3fff57d0: 00000000 3fff0000 00000000 4020b900
3fff57e0: 00000000 00000000 00000000 00000000
3fff57f0: 00000000 00000100 3fff636c 0000000f
3fff5800: 00000000 3fff6bd4 0000000f 00000000
3fff5810: 3fff6bec 0000000f 00000000 00000000
3fff5820: 3fff45ca 00000000 3fff4574 4022376c
3fff5830: 00000000 00000000 00000000 00000000
3fff5840: 00000000 00000000 40295a86 3fff1d24
3fff5850: 3fff45ca 0000000c 3fff1ae0 40222090
3fff5860: 3fff45ca 00000000 3fff3248 4024ad88
3fff5870: 00000000 00000000 00000000 402567d0
3fff5880: 3fff7294 0000002f 00000015 feefeffe
3fff5890: feefeffe feefeffe feefeffe 3fff4898
3fff58a0: 3fffdad0 00000000 3fff4892 4020d44c
3fff58b0: feefeffe feefeffe 3fff48a0 402109b4
<<<stack<<<
tail 8
chksum 0x2d
csum 0x2d
v09826c6d
~ld
U
Of course, I can flash newest builds always over ArduinoIDE. But I'd like to use EasyOTA function, it's useful! :]
Any help what's going wrong or how can I correct this? Thanks! :]
