Any WiFi after flash
NickOver
#1 Post by NickOver » 13 Apr 2018, 19:29
After flash ESP01(1kb) any wifi named ESP_Easy_0 or ESP_0 isn't avalible.
Flashing tool give me info is everything ok, so i remove converter and connect power (
VCC + CH_PD to VCC
GND to GND
I don't got these networks so i connect to converter (
TX - RX
RX-TX
VCC + CH_PD - VCC
GND - GND
to get serial monitor outputs:
og[k⸮⸮~oBwj⸮kC⸮⸮[og[k⸮⸮~o⸮{ccs⸮ZRnrR⸮R⸮nz⸮nzB⸮⸮F⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮C⸮⸮N⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮⸮2c_⸮rS⸮f⸮j⸮_⸮⸮⸮⸮S⸮
I try flash it second time but efect are that same.
only have new network names 'FaryLink_1D796A'. I try to connect with them, but i'm all time disconnected and connected. Open browser give mi info i dont have network (i expected easyESP config page).
What can I do?
I wired somethink wrong?
Re: Any WiFi after flash
#2 Post by grovkillen » 13 Apr 2018, 19:44
Seems like you haven't been able to flash it.
NickOver
#3 Post by NickOver » 13 Apr 2018, 20:13
If its true why FaryLink_1D796A network are shown?
#4 Post by grovkillen » 13 Apr 2018, 20:16
Because that is the original FW still alive and kickin'
NickOver
#5 Post by NickOver » 13 Apr 2018, 20:20
Ok, so how i can remove them?
#6 Post by grovkillen » 13 Apr 2018, 20:28
Have you looked in the wiki? There's a guide for the ESP unit. And are you sure that you use the correct BIN? Are your unit equipped with the mem-chip labeled PUYA?
NickOver
#7 Post by NickOver » 13 Apr 2018, 21:14
I use
ESP_Easy_mega-20180413_normal_ESP8266_1024.bin
so i think it's correct.
Yeah, have PUYA label.
Now i loaded blank_1MB.bin (its bin with only 0) and ESP dont broadcast any network. Wi will see what been after load one mor time EasyESP binary.
EDIT
Ok, after load EasyESP i got network named 'ASP_1D796A' but all time im connect and after few seconds disconnected. I burned it, right?
EDIT2
Is load in lower bitrate shoud help?
EDIT3
Loading it to new ESP have that same result so i think it's somethink with soft. Did someone have any idea?
#8 Post by grovkillen » 13 Apr 2018, 21:35
You need to upload the ESP_Easy_mega-2018XXXX_dev_ESP8266PUYA_1024.bin
NickOver
#9 Post by NickOver » 13 Apr 2018, 22:41
Ok, i upload binary:
ESP_Easy_mega-20180413_dev_ESP8266PUYA_1024.bin
Before that i clear memory.
Now i got ESP_Easy_0, i log in, set network, set password, im redirect to "timer" page and after few seconds connection are broken i i got info about getting IP address. After few second network disapear, on router i didn't see any connected device.
#10 Post by grovkillen » 14 Apr 2018, 00:16
Do you have it connected to the computer/programmer? Possible to look in serial log?
NickOver
#11 Post by NickOver » 14 Apr 2018, 10:43
After debug via serial monitor it's look like it alive, and broadcast on 192.168.0.192. But it's strange why my ruter dont show it. Ok, thank you so much for help. You have big beer from me ;)
Users browsing this forum: No registered users and 88 guests
