Can't get Rules Tutorial to work
whatsupskip
#1 Post by whatsupskip » 21 May 2018, 08:28
I am just starting out with Rules, so I thought I would do the most basic example: https://www.letscontrolit.com/wiki/inde ... rial_Rules
However it doesn't seem to work. The LED turns on and then just stays on.
Have a made a basic mistake in the code?
On System#Boot do
 gpio,12,0
 timerSet,1,10
On Rules#Timer=1 do
 if [E1SW1#Switch]=1
 gpio,12,0
 gpio,12,1
 timerSet,1,10
GIT version: mega-20180515
Wemos D1 Mini (v1 clone)
Any ideas would be great!
cyberclwn
Re: Can't get Rules Tutorial to work
#2 Post by cyberclwn » 21 May 2018, 09:52
Did you also do this part:
To be able to read the state of the LED (on or off) a switch input is created with the same GPIO port
danmero
#3 Post by danmero » 21 May 2018, 13:04
On Rules#Timer=1 do
 if [E1SW1#Switch]=1  # DEVICE
 gpio,12,0 # GPIO
- You can SET the the state of GPIO from Rules.
- You can't GET the state of the GPIO from Rules. For this you have to use plugins , aka declare the GPIO as device on Device Tab.
  1. Device name: E1SW1
  2. Type: Switch
  3. GPIO: 0
As you can see from your example you call the device name: [E1SW1#Switch]
Regards,
whatsupskip
#4 Post by whatsupskip » 24 May 2018, 05:06
Thank you both for your help.
I hadn't set up the switch device.
I edited the Wiki page to clarify the set up of the switch.
Users browsing this forum: Bing [Bot] and 101 guests
