DHT Values by http command
Frankinho
#1 Post by Frankinho » 26 May 2018, 20:28
i need collect the values from the DHT Sensor by HTTP commands http://<espeasyip>/control?cmd=<command> into php
Is there an option like the other way to switch the relais by commands?
danmero
Re: DHT Values by http command
#2 Post by danmero » 26 May 2018, 21:13
You can switch by http request or be MQTT subscription.
Regards,
Frankinho
#3 Post by Frankinho » 26 May 2018, 21:42
The relais was only written as an example
I need the dht device temperature value as http command
danmero
#4 Post by danmero » 27 May 2018, 01:09
Can you extract the value from http://<IP>/json
Do you want something else?
Regards,
Frankinho
#5 Post by Frankinho » 29 May 2018, 16:57
Thanks, it works perfect for me :D
