Why some kind of events does not show on OLED SSD1306?
xury
#1 Post by xury » 26 Jun 2018, 23:42
Hi I wanted to send some of data using SendTo
And its works because I see it in logs on another device with values but I can't display the value on OLED.
Same as I tried to display [Clock#Time] its also not show.
I know %systime% is displayed well, but why some values is possible to display and some not?
I found round up solution putting event to dummy task but I still curious the reason.
Re: Why some kind of events does not show on OLED SSD1306?
#2 Post by TD-er » 27 Jun 2018, 23:40
In the file StringConverter.ino you can see all the "aliases" made which can be used to create strings.
These are marked with %text%
When using square brackets, you normally address output values from a task.
Typically [name#value] where "name" is the name given to the task (must be unique) and "value" is the name of the value of that task.
Events are typically used to mark a moment in time to trigger a rule to start.
So you would use the event in the rule to start executing a rule.
