Is there a way to trigger a sensor reading besides just the time parameter in the device settings?
Say I'd like a switch that changes position to force an ultrasonic sensor to take a reading outside its regular 60 second timing.
Is that possible?
Trigger sensor reading
Re: Trigger sensor reading
Yes you do a rule for that and trigger another task using TaskRun. Or you can just publish the current value when the switch is triggered. But you need to use rules either way.
Yeah republish won't fit. If a switch changes it likely means the reading will change.grovkillen wrote: ↑26 Jul 2018, 13:54 Yes you do a rule for that and trigger another task using TaskRun. Or you can just publish the current value when the switch is triggered. But you need to use rules either way.
taskrun...thanks, that'll probably be it then
Users browsing this forum: Bing [Bot] and 62 guests
