I am in trouble.
I have a Wemos D1 with EspEasy.
A resistor of 10K pulls D2 GPIO4 down to GND.
When I connect the swith and press it, the D2 connects to 3V3.
But the Wemos goes in reboot.
And because I made the mistake of using the boot state checkbox on the switch device. My Wemos is now in a reboot loop.
Please help !
WIFI : Connected! IP: 192.168.0.40 (ESP_Easy_0)
EVENT: System#Boot
SW : State 0
EVENT: Drukknop#Switch=0.00
ACT : longpulse,5,1,3
SW : GPIO 5 Pulse set for 3 S
Panic /home/travis/.platformio/packages/framework-arduinoespressif8266/cores/esp8266/core_esp8266_main.cpp:131 loop_task
ctx: sys
sp: 3ffffdd0 end: 3fffffb0 offset: 01b0
>>>stack>>>
3fffff80: 401007ca 00000000 00000002 3fff31a0
3fffff90: 00000000 3fffdad0 3fff3198 40203381
3fffffa0: 3ffeb3b0 40000f49 3fffdab0 40000f49
<<<stack<<<
ets Jan 8 2013,rst cause:2, boot mode:(3,7)
tail 8
chksum 0x2d
csum 0x2d
v09826c6d
~ld
⸮U
Help needed for reboot loop. Panic Loop_task
Re: Help needed for reboot loop. Panic Loop_task
You could connect the RX and TX pins of the serial port together.
This will trigger a factory reset (and thus wipe all settings).
Just flashed and everything was ok.
Nothing was lost
Seems like the Wemos DC Power Shield is the reason for the reboots.
Don't know how to fix. When I use the usb power connection on the wemos it works fine.
@Moderator: Please close this thread
Nothing was lost
Users browsing this forum: Google [Bot] and 31 guests
