Only first 4 light turn up
regio
#1 Post by regio » 11 Aug 2018, 21:15
Hello all,
I have a ESP8266 , ESP-01S RGB LED, WS2812B led strip and a S - 30 - 5 30W 5V / 6A Switch Power Supply Driver. I have uploaded a script to the ESP8266 with arduino IDE. I used Adafruit Neopixel strandtest and changed the number of leds than saved the file and uploaded it. Now only the first led turn u. So i Googled em found some post that say i need a logic level converter. So i bod a LOGIC LEVEL CONVERTER BI-DIRECTIONAL from sparkfun. I have connected the LV to the 3.3V of my raspberrypi and the HV to 5v on the Pi. Connected the yellow wire from ESP-01S RGB LED to the LV channel of the converter and made a connection from the HV channel to the signal wire of the led strip. But even with the converter connected only 5 light turn on. I have really no idea anymore on what the problem good be.
Anyone has a solution or a idea what good be wrong in my setup.
papperone
Re: Only first 4 light turn up
#2 Post by papperone » 12 Aug 2018, 10:33
it's too vague the description to be able to help you, can you please post a picture on how you connected everything?
only guess is that you are powering the strip wrongly or the strip has harware issues...
regio
#3 Post by regio » 12 Aug 2018, 17:48
Thanks for the reply.
here a photo of the setup.
https://ibb.co/jPOSBU
Hope this make it some what clearer.
papperone
#4 Post by papperone » 13 Aug 2018, 00:39
sorry but I cannot understand, the wiring is not clear and I see as well a Raspberry which no idea what's the purpouse of... :shock:
regio
#5 Post by regio » 13 Aug 2018, 19:18
Have been playing around some more. And it turns out that Adafruit Neopixel and Neopixelbus by makuna examples don't work( this is becose the library uses GPIO3 and i use PIN2). Iff i use the FastLED examples the all work.
I now have the sample code that works:
#include <FastLED.h>
#define LED_PIN     2
#define NUM_LEDS    300
#define BRIGHTNESS  64
#define LED_TYPE    WS2812
#define COLOR_ORDER GRB
CRGB leds[NUM_LEDS];
#define UPDATES_PER_SECOND 100
// This example shows several ways to set up and use 'palettes' of colors
// with FastLED.
// These compact palettes provide an easy way to re-colorize your
// animation on the fly, quickly, easily, and with low overhead.
// USING palettes is MUCH simpler in practice than in theory, so first just
// run this sketch, and watch the pretty lights as you then read through
// the code.  Although this sketch has eight (or more) different color schemes,
// the entire sketch compiles down to about 6.5K on AVR.
// FastLED provides a few pre-configured color palettes, and makes it
// extremely easy to make up your own color schemes with palettes.
// Some notes on the more abstract 'theory and practice' of
// FastLED compact palettes are at the bottom of this file.
CRGBPalette16 currentPalette;
TBlendType    currentBlending;
extern CRGBPalette16 myRedWhiteBluePalette;
extern const TProgmemPalette16 myRedWhiteBluePalette_p PROGMEM;
void setup() {
    delay( 3000 ); // power-up safety delay
    FastLED.addLeds<LED_TYPE, LED_PIN, COLOR_ORDER>(leds, NUM_LEDS).setCorrection( TypicalLEDStrip );
    FastLED.setBrightness(  BRIGHTNESS );
    currentPalette = RainbowColors_p;
    currentBlending = LINEARBLEND;
void loop()
    ChangePalettePeriodically();
    static uint8_t startIndex = 0;
    startIndex = startIndex + 1; /* motion speed */
    FillLEDsFromPaletteColors( startIndex);
    FastLED.show();
    FastLED.delay(1000 / UPDATES_PER_SECOND);
void FillLEDsFromPaletteColors( uint8_t colorIndex)
    uint8_t brightness = 255;
    for( int i = 0; i < NUM_LEDS; i++) {
        leds[i] = ColorFromPalette( currentPalette, colorIndex, brightness, currentBlending);
        colorIndex += 3;
// There are several different palettes of colors demonstrated here.
// FastLED provides several 'preset' palettes: RainbowColors_p, RainbowStripeColors_p,
// OceanColors_p, CloudColors_p, LavaColors_p, ForestColors_p, and PartyColors_p.
// Additionally, you can manually define your own color palettes, or you can write
// code that creates color palettes on the fly.  All are shown here.
void ChangePalettePeriodically()
    uint8_t secondHand = (millis() / 1000) % 60;
    static uint8_t lastSecond = 99;
    if( lastSecond != secondHand) {
        lastSecond = secondHand;
        if( secondHand ==  0)  { currentPalette = RainbowColors_p;         currentBlending = LINEARBLEND; }
        if( secondHand == 10)  { currentPalette = RainbowStripeColors_p;   currentBlending = NOBLEND;  }
        if( secondHand == 15)  { currentPalette = RainbowStripeColors_p;   currentBlending = LINEARBLEND; }
        if( secondHand == 20)  { SetupPurpleAndGreenPalette();             currentBlending = LINEARBLEND; }
        if( secondHand == 25)  { SetupTotallyRandomPalette();              currentBlending = LINEARBLEND; }
        if( secondHand == 30)  { SetupBlackAndWhiteStripedPalette();       currentBlending = NOBLEND; }
        if( secondHand == 35)  { SetupBlackAndWhiteStripedPalette();       currentBlending = LINEARBLEND; }
        if( secondHand == 40)  { currentPalette = CloudColors_p;           currentBlending = LINEARBLEND; }
        if( secondHand == 45)  { currentPalette = PartyColors_p;           currentBlending = LINEARBLEND; }
        if( secondHand == 50)  { currentPalette = myRedWhiteBluePalette_p; currentBlending = NOBLEND;  }
        if( secondHand == 55)  { currentPalette = myRedWhiteBluePalette_p; currentBlending = LINEARBLEND; }
// This function fills the palette with totally random colors.
void SetupTotallyRandomPalette()
    for( int i = 0; i < 16; i++) {
        currentPalette[i] = CHSV( random8(), 255, random8());
// This function sets up a palette of black and white stripes,
// using code.  Since the palette is effectively an array of
// sixteen CRGB colors, the various fill_* functions can be used
// to set them up.
void SetupBlackAndWhiteStripedPalette()
    // 'black out' all 16 palette entries...
    fill_solid( currentPalette, 16, CRGB::Black);
    // and set every fourth one to white.
    currentPalette[0] = CRGB::White;
    currentPalette[4] = CRGB::White;
    currentPalette[8] = CRGB::White;
    currentPalette[12] = CRGB::White;
// This function sets up a palette of purple and green stripes.
void SetupPurpleAndGreenPalette()
    CRGB purple = CHSV( HUE_PURPLE, 255, 255);
    CRGB green  = CHSV( HUE_GREEN, 255, 255);
    CRGB black  = CRGB::Black;
    currentPalette = CRGBPalette16(
                                   green,  green,  black,  black,
                                   purple, purple, black,  black,
                                   purple, purple, black,  black );
// This example shows how to set up a static color palette
// which is stored in PROGMEM (flash), which is almost always more
// plentiful than RAM.  A static PROGMEM palette like this
// takes up 64 bytes of flash.
const TProgmemPalette16 myRedWhiteBluePalette_p PROGMEM =
    CRGB::Red,
    CRGB::Gray, // 'white' is too bright compared to red and blue
    CRGB::Blue,
    CRGB::Black,
    CRGB::Red,
    CRGB::Gray,
    CRGB::Blue,
    CRGB::Black,
    CRGB::Red,
    CRGB::Red,
    CRGB::Gray,
    CRGB::Gray,
    CRGB::Blue,
    CRGB::Blue,
    CRGB::Black,
    CRGB::Black
// Additionl notes on FastLED compact palettes:
// Normally, in computer graphics, the palette (or "color lookup table")
// has 256 entries, each containing a specific 24-bit RGB color.  You can then
// index into the color palette using a simple 8-bit (one byte) value.
// A 256-entry color palette takes up 768 bytes of RAM, which on Arduino
// is quite possibly "too many" bytes.
// FastLED does offer traditional 256-element palettes, for setups that
// can afford the 768-byte cost in RAM.
// However, FastLED also offers a compact alternative.  FastLED offers
// palettes that store 16 distinct entries, but can be accessed AS IF
// they actually have 256 entries; this is accomplished by interpolating
// between the 16 explicit entries to create fifteen intermediate palette
// entries between each pair.
// So for example, if you set the first two explicit entries of a compact
// palette to Green (0,255,0) and Blue (0,0,255), and then retrieved
// the first sixteen entries from the virtual palette (of 256), you'd get
// Green, followed by a smooth gradient from green-to-blue, and then Blue.
Users browsing this forum: Google [Bot] and 25 guests
