I am not able to send the value of an ESp keypad device into a user vari in Domoticz.
What I have is the Rule:
If [keypad#ScanCode] = 2.00
TaskValueSet 1,1,[keypad#ScanCode]
SendTo HTTP 192.168.1.123,8080,/json.htm?type=command¶m=updateuservariable&vname=Varkeypad&vtype=2&vvalue=[keypad#ScanCode]
Endif
The IP is a temp IP of my Domoticz server, The user var in domoticz is called Varkeypad as a string
The logfile show
3098184 : ScanCode=0x2
3098203 : EVENT: keypad#ScanCode=2.00
3098366 : ACT : TaskValueSet 1,1,2
3098409 : ACT : SendTo HTTP 192.168.1.123,8080,/json.htm?
type=command¶m=updateuservariable&vname=Varkeypad&vtype=2&vvalue=2
Why is there no value in the Varkeypad in Domoticz??
Domotics user variable
Re: Domotics user variable
The space between "SendTo" and "HTTP" should be removed.
thanks, I removed the space but still no update of the user var in Domoticz.
Any more suggestions?
I know the IP is ok and the name of the Var as wel.
I think this should be your line:
Not sure if they changed it, but last time i used this it was not the number of the type, but the name.
SendToHTTP 192.168.1.123,8080,/json.htm?type=command¶m=updateuservariable&vname=Varkeypad&vtype=string&vvalue=[keypad#ScanCode]
Still no progress. This is what I have:
On keypad#ScanCode Do
If [keypad#ScanCode] = 8.00
SendToHTTP 192.168.1.123,8080,/json.htm?type=command¶m=updateuservariable&vname=Varkeypad&vtype=String&vvalue=25
Endif
If I put
http://192.168.1.123:8080/json.htm?type ... &vvalue=21
in my browser, the user var in Domoticz is be updated but using the script from my ESP is not updating. The dummy field is updated but the Var not.
Endif
If I put
In Domoticz, you might want to try to accepts “instructions” within Domoticz without login credentials from the local network.
In Domoticz goto -> SETUP -> SETTINGS ->
In the option field “Local Networks (no username/password):” insert your IP range ( 192.168.1.* ).
Perhaps this might get you further.
The IP adding in Domoticz did the job. Now it is working! Thanks all for the good suggestions.
Users browsing this forum: Google [Bot] and 105 guests
