Public MQTT Broker not working
TommoT1
#1 Post by TommoT1 » 17 Aug 2018, 12:02
Hi there I'm quite new to espEasy and unable to solve my problem.
I use the v2.0-20180322 Version on an SonOff S20 and on an ESP-01.
When I try to connect to test.mosquitto.org on Port 1883 I get :
269857394 : MQTT : Intentional reconnect
269857474 : MQTT : Failed to connect to broker
269859394 : MQTT : Intentional reconnect
269859478 : MQTT : Failed to connect to broker
269861394 : MQTT : Intentional reconnect
all the time.
Use Hostname: test.mosquitto.org
Port 1883
Username and Password: blank
Controller Subscribe:/OWNSUBJECT/#
Controller Publish:/OWNSUBJECT/Status
I tried the Domoticz MQTT
the OpenHAB MQTT
and PiDome MQTT.
all the same.
When I set up a local MQTT Broker just in its basic config it works out of the box (with IP adress instead of Hostname).
I also tried the latest ESP_Easy_mega-20180809_normal_ESP8266_1024.bin, same behaviour.
I also made a test account on www.cloudmqtt.com, same same.
Does anybody has a hint for me to get it working?
Tom
oisisi
Re: Public MQTT Broker not working
#2 Post by oisisi » 17 Aug 2018, 16:55
Try to replace the hostname with the IP address 37.187.106.16 (and change the dropdown accordingly).
TommoT1
#3 Post by TommoT1 » 18 Aug 2018, 00:40
I forgot to mention, i also did that with no change :-(
Thomas
oisisi
#4 Post by oisisi » 18 Aug 2018, 09:31
Then I am also out of ideas. Is your issue perhaps related to this topic?
TommoT1
#5 Post by TommoT1 » 19 Aug 2018, 12:26
Yes, might be.
I'm running out of ideas, testet ESPURNA and TASMOTA just for the MQTT part.
Both work flawlessly with public brokers.
But configurability of espeasy ist way better.
#6 Post by TD-er » 19 Aug 2018, 20:03
Please check also your network settings on the ESP node.
Do you use DHCP? Is the gateway set right?
TommoT1
#7 Post by TommoT1 » 19 Aug 2018, 23:53
Hi TD-er,
Yes I use DHCP, also tried fixed IP with correct gateway, no change.
I also tried setting up a local mosquitto -> works.
Then I forwarded a port from my router to my local broker and told espeasy my dyndns address (and trie the same with current IP Address) with the open port -> failed to connect to broker,
the same as with test.mosquitto.org
By the way, NTP works, so there shouldn' t be a gateway problem.
kenkoknz
#8 Post by kenkoknz » 20 Aug 2018, 03:33
Looks like you tried just about everything. Probably this may not be your solution, but just on the off chance, try changing the subscribe and publish topic to without the leading slashes ie:
Controller Subscribe:OWNSUBJECT/#
Controller Publish:OWNSUBJECT/Status
try on a fresh esp.
Cheers,
Ken
TommoT1
#9 Post by TommoT1 » 20 Aug 2018, 11:26
Hi Ken!
During all the testing I tried this too and at the moment it runs without the leading slashes,
but only connects to my local broker.
I everybody else capable to establish a connection to (for example) test.mosquitto.org ?
Thomas
kenkoknz
#10 Post by kenkoknz » 20 Aug 2018, 11:54
Have you try broker.hivemq? I use hivemq and it works good without any problems. I also tried adafruit.io and that also works.
Ken
TommoT1
#11 Post by TommoT1 » 20 Aug 2018, 19:15
Hey Ken!
Thanks, I tried broker.hivemq.com and it worked instantaneously!
Great tip, thank you!
But still wondering why the mosquitto broker won't work when outside its local network....
Thomas
Users browsing this forum: Bing [Bot] and 21 guests
