Public MQTT Broker not working
Hi there I'm quite new to espEasy and unable to solve my problem.
I use the v2.0-20180322 Version on an SonOff S20 and on an ESP-01.
When I try to connect to test.mosquitto.org on Port 1883 I get :
269857394 : MQTT : Intentional reconnect
269857474 : MQTT : Failed to connect to broker
269859394 : MQTT : Intentional reconnect
269859478 : MQTT : Failed to connect to broker
269861394 : MQTT : Intentional reconnect
all the time.
Use Hostname: test.mosquitto.org
Port 1883
Username and Password: blank
Controller Subscribe:/OWNSUBJECT/#
Controller Publish:/OWNSUBJECT/Status
I tried the Domoticz MQTT
the OpenHAB MQTT
and PiDome MQTT.
all the same.
When I set up a local MQTT Broker just in its basic config it works out of the box (with IP adress instead of Hostname).
I also tried the latest ESP_Easy_mega-20180809_normal_ESP8266_1024.bin, same behaviour.
I also made a test account on www.cloudmqtt.com, same same.
Does anybody has a hint for me to get it working?
Tom
all the time.
Port 1883
the OpenHAB MQTT
and PiDome MQTT.
all the same.
Tom
Re: Public MQTT Broker not working
Try to replace the hostname with the IP address 37.187.106.16 (and change the dropdown accordingly).
I forgot to mention, i also did that with no change
Thomas
Thomas
Then I am also out of ideas. Is your issue perhaps related to this topic?
Yes, might be.
I'm running out of ideas, testet ESPURNA and TASMOTA just for the MQTT part.
Both work flawlessly with public brokers.
But configurability of espeasy ist way better.
Please check also your network settings on the ESP node.
Do you use DHCP? Is the gateway set right?
Hi TD-er,
Yes I use DHCP, also tried fixed IP with correct gateway, no change.
I also tried setting up a local mosquitto -> works.
Then I forwarded a port from my router to my local broker and told espeasy my dyndns address (and trie the same with current IP Address) with the open port -> failed to connect to broker,
the same as with test.mosquitto.org
By the way, NTP works, so there shouldn' t be a gateway problem.
Looks like you tried just about everything. Probably this may not be your solution, but just on the off chance, try changing the subscribe and publish topic to without the leading slashes ie:
Controller Subscribe:OWNSUBJECT/#
Controller Publish:OWNSUBJECT/Status
try on a fresh esp.
Cheers,
Ken
try on a fresh esp.
Cheers,
Ken
Hi Ken!
During all the testing I tried this too and at the moment it runs without the leading slashes,
but only connects to my local broker.
I everybody else capable to establish a connection to (for example) test.mosquitto.org ?
Thomas
Thomas
Have you try broker.hivemq? I use hivemq and it works good without any problems. I also tried adafruit.io and that also works.
Ken
Ken
Hey Ken!
Thanks, I tried broker.hivemq.com and it worked instantaneously!
Great tip, thank you!
But still wondering why the mosquitto broker won't work when outside its local network....
Thomas
Thomas
Users browsing this forum: Google [Bot] and 108 guests
