Still a little help needed / HTTP send command
Sasch600xt
#1 Post by Sasch600xt » 28 Sep 2018, 21:34
hello all :)
i am still a little fighting on my side here.
Could someone give this a try with a newer version like 201809xx :
on System#Boot do
Monitor GPIO,0
Monitor GPIO,4
Monitor GPIO,5
Monitor GPIO,16
timerSet,1,30
on GPIO#16=1 do
    SendToHTTP 192.168.123.10,8080,/json.htm?type=command&param=switchlight&idx=17&switchcmd=On
on GPIO#16=0 do
    SendToHTTP 192.168.123.10,8080,/json.htm?type=command&param=switchlight&idx=17&switchcmd=Off
I do not even get a message to receiv.
With 20180826 i get "GET /json.htm?type=command¶m=switchlight&idx=17&switchcmd=Off" wich i can work with and all is fine.
After posting all my trouble in here, TD-er gave me a hint my receiver script for php is not a very good code.
So a friend and mine designed the receiver script new from scratch. Then i tryed newer images as 20180826 and i dont even get a message from ESP-Easy.
So now i am not sure it is only the falt of my receiver scripts.
I do not get any raw HTTP messages with higher the 20180826.
No controller user and no password is in use.
Can this maybe the problem ?
Hardware is nodemcu lolin V3
image "normal,4096"
Thank you for your help!
Sascha
Re: Still a little help needed / HTTP send command
#2 Post by grovkillen » 28 Sep 2018, 22:38
If you try this command in the command line on the tools page:
Do you still not get a message sent?
Sasch600xt
#3 Post by Sasch600xt » 28 Sep 2018, 23:01
thank you for your answere.
this worked once and i got the message (one step further)
but after the command the ESP freezed and i had to do a hard reset.
Sascha
EDIT: i did it a few times and always after send the command from tools form the ESP freezed.
#4 Post by grovkillen » 28 Sep 2018, 23:28
You should open a issue on GitHub. Sounds like a bug
