Syntax for OpenHAB folder
Sasch600xt
#1 Post by Sasch600xt » 02 Oct 2018, 14:35
Hello all :)
i try to get an folder after root.
but i am not sure how the correct syntax will be ?
i did try :
Testbereich
/Testbereich
/Testbereich/
but nothing worked so far :(
here is a screenshot:
Screenshot 2018-10-02 14.30.46.png (95.5 KiB) Viewed 462 times
thank you so much for your help
Sascha
Re: Syntax for OpenHAB folder
#2 Post by grovkillen » 02 Oct 2018, 14:39
That setting got noting to do with folders or root. It's the topic settings for the MQTT protocol.
Sasch600xt
#3 Post by Sasch600xt » 02 Oct 2018, 14:41
oh, ok.
then it was a missunderstood of my head :)
waspie
#4 Post by waspie » 02 Oct 2018, 14:50
what is it you're trying to do?
if you want to see what ESP is sending to MQTT so you know how to define your items in openhab then you can sub to mqtt like:
mosquitto_sub -h IPofYOURbroker -t '#'
and then get the ESP to send something. then you'll see exactly what's happening and you can transfer that to openhab
output from mosquitto:
/UtilityRoom/Furnace_Temp/FUR_IN 71.71
/UtilityRoom/furnaceTemp/FUR_OUT 70.81
/UtilityRoom/Evaporator_Temp/EVP_TEMP 71.94
/UtilityRoom/uptime/urUptime 4238.00
/beacon/sensor/journey-signal/state -71
so an item definition in openhab would look like:
Number	Evap 						"Furnace evap Temp [%.1f °F]"		<temperature>	(nestTemps1,gTemps)		{ mqtt="<[oh2:/UtilityRoom/Evaporator_Temp/EVP_TEMP:state:default]" }
Users browsing this forum: No registered users and 5 guests
